1 - 11 of 11 Posts
Hey there M-F's,
Can I get a parts list for a hydro clutch conversion for my 97 900 ?
Cheers, :thefinger:
You should mount that subframe with wingnuts for easy removal:). Master, slave, lines (2 pieces) and a whole pedal pack from a hydro car. Swapped over a 1995 with a member here, he did most of the inside work but we needed to drill a new hole in the firewall for the master
genuinesaab sells a kit. if you look at that you will see what you need. they also have a template for the hole you need to put in the firewall.
Discussion Starter · #4 ·
lols, I agree with wingnuts. I've had it in and out that many times.
I'm pretty good at it it now.
... So that list is all I need then?
Iv'e seen that GS kit. It's a shame it's only for a LHD.
Confirmed the pedals are different RHD vs LHD?
Slave cylinder
Hydraulic line from slave to outside of trans
Bracket to hold disconnect fitting on trans
Hydraulic line from trans to master cylinder
Master cylinder/clutch pedal
Rubber hose and clamps from clutch master cylinder to brake master cylinder reservoir
Brake master cylinder reservoir with compatible nipple for hydraulic clutch
Eeuro used to sell a more complete kit then GS that was also cheaper.
Discussion Starter · #6 ·
Thanks, Nice list.
I'll get onto "Saab-wreck" in Melbourne, They should have everything.
Thanks, Nice list.
Also the most expensive place to get stuff!
Discussion Starter · #8 ·
Noob Question.
Hey Guys,
Is there a difference between the Turbo 93 and the NON-Turbo 93 Hydralic clutch operation? I wouldn't think so :eek:
I may have a chance to buy a non -turbo 1998 vert 93 this Friday *cheap*
The 98's were hydro operation,...... Wern't they???
Was first year for hydro here in the states. Operation should be the same, only difference may be clutch.
Discussion Starter · #11 ·
I just bought another vert. :-0).......... With a hydro clutch, It comes Monday.
1 - 11 of 11 Posts
