1 - 3 of 3 Posts
Trollerator
has anyone here with a lowered Saab found it tough to get a proper alignment and had to use a camber kit?
There is no camber adjustment for the front. Typically there is no need to change it unless you are using it in competition. The rear hubs can be shimmed with spacers from the 9-5 to get the rear camber where you want. But again since solid axle there is usually no need.
1 - 3 of 3 Posts
