1 - 7 of 7 Posts
Bought a 87 900 S. Ignition is fucked on it (have to start with a screwdriver). The previous owner tried swapping in another ignition cylinder but that didn't fix the problem.
So I have 2 ignition cylinders with different keys, and neither key works in the doors. So I can't lock the doors (don't have a key for them).
1 - Is it possible to give a dealer my VIN and have new door keys recut?
2 - How hard is it to swap door key cylinders?
It's an '87 900 S, what do you need to lock the doors for?*
Yeah, dealer can cut a key from the VIN I believe.
There are only like 25 different possible patterns for the c900 SAAB keys. I have a ring of them that I've grabbed from salvage yard cars over the years. That ring has saved my ass a few times. Most recently my son went back to college with the keys to his POS vert I was driving to work.
Yes, you can go to the stealership and get a new one cut with the vin. Like turbo says though there are a limited number of patterns for saab 900 keys!
The cylinders are pretty easy to swap in the door. You may need to pull one out to get the code off it to get a key cut. Good chance that for a 87 it can't be done from the VIN
That's pretty cool. Could come in handy in a post-apocalyptic warzone.
Good point to consider... the door locks may not be the originals. You could get a VIN-cut key that doesn't even fit. Pulling one to take to a dealer or locksmith might be a better idea.
1 - 7 of 7 Posts
