1 - 9 of 9 Posts
I was out driving today, and everything was working great. Come to a stop sign and when I try to accelerate it feels like im in third. So I look down but im still in first. So I try to take itout of gear and the shifter is really really sloppy. I put it back into first and same thing happens. I check the gear selector and it seems fine also check the clutch cable and that's fine as well. Isthis a blown transmission?
Maybe goofed up shifter linkage.
Sounds like a linkage problem.
Discussion Starter · #5 ·
well it seems as though third is where first is....no second gear....4th seems to be there and 5th seems in the right place...and reverse wont go into gear.
Discussion Starter · #7 ·
its a 96' if its only the linkage that would be great. Im having a shop take a look at it tomorrow or friday.
I can probably hook you up with an updated linkage if you need it...
1 - 9 of 9 Posts
