Alloy Pedal Pad Conversion
1.6K views 2 replies 2 participants last post by  ReBjörn
Now im not a Fan at all of those "Alloy Pedal Pad Kits"(mostly Made in China)with the Clips and Cheap Screws,they almost always fall apart and are Dangerous but i came accross these(ALLOY BRAKE / CLUTCH PEDAL PAD on eBay (end time 05-Mar-11 08:26:11 GMT)) on Eblay,the Seller was UK based so i ordered 3 as i wanted to do all 3 Pedals the same.
Fitted them up yesterday and had to trim the Brake Pedal about 10/15mm on the right side and flatten out the Throttle Pedal but that was it,they feel great and dont slip at all,and look cool too.
#3 · (Edited)
The Rubber Grips are a one piece slip in from the back, with 2 holes empty to fit countersunk screws.
If the link is still good i'd nab a couple as he is'nt an "auto parts" ebayer but has maybe a half dozen left(i'll leave out the cost till you have a Set;)),try searching ebay.uk for a Seller named "hashryla" and let me know how you go,maybe even post up a photo here of your Sonett with them screwed on? Cheers.
ps.What Series Sonett do you have?,not knowing to much about them i just did a quick google and agree,they would look smart down in the Footwell.
