1 - 6 of 6 Posts
ok so heres the problem.. I am working on a friends 91 900S and I replaced the rear pads, rotors, calipers and adjusted the HB cables and now when I turn the car on the abs light is steady on...I have been driving the car around the last couple of days and the brakes feel fantastic but I cant tell if the abs is working. Mind you im not sure if the abs light was on before and the owner didnt know either.
I have read that I should clean the abs wheel sensor , how do you clean these things? If not cleaning anything else I should be looking at..
Discussion Starter · #4 ·
I do my own work......I didnt see anything in the bentley about checking codes but I could have not have seen it i'll take another look..
Discussion Starter · #5 ·
getting back to my original question....how does one clean a sensor??
1 - 6 of 6 Posts
