1 - 14 of 14 Posts
any body know hwta management is in a 96 9000 2.3t? aand is it the same as a 94 9000 2.3??? because i know 94 is obdI and 96 is obdII well im pretty sure so is the 94 before emitions difrnet then 96 management? thanks
p.s. im not retarded i just dont know how to spell or proofread =) thanks abunch and kinda need an awnser soonish
Correct me if I'm wrong, but I believe OBDII didn't start until '98. '96 was likely T5. As was the '94.
Discussion Starter · #7 ·
i just emailed him ironicly haha but i do have the 96 intakemany on the 94 motor but you dont think that will set off the CElight? and if im not mistaken isnt 94 cse difrent engine code then 96 cs? so why would it be diffrent? i think the ratio is diffrent because i think cs is b234e and automatic cse in 94 is b234LA idk i just dont understand why they are diffrent engine codes if they are able to swap.
I just looked at the other thread, 96 intake and wiring on there and you should be good to go. No reason I can think of that'll give a cel
Discussion Starter · #9 ·
oh cool, and do you know anywhere i can get a clutch kit for a reasonable price while its out why not right? haha im down about 800 alltogether now and i found a kit for 279ish i dont need the flywheel. and thank you so much for all your helpi have alot to learn about these cars haha im almost 17 =)
the ng900's actually had a "pre" OBD2 in preparation for the 1996 change over - so most 1994 & 1995 ng900's even have the OBD2 Diagnostic Connector. 1993-1995 9000's have all the same communications as an OBD2 car, but do not have the OBD2 connector until 1996.
Does the 1994 ECU (T5) have TCS? A TCS ECU will not work in a non-TCS car. It will start and idle oddly - but there won't be throttle response support or anything else beyond that. (At least in my 1995 9000 CS which I tried it on)
OBD1 or OBD2 T5 is still T5
1 - 14 of 14 Posts
