9000 aero oil cooler lines
1.4K views 5 replies 4 participants last post by  Banman
I am looking for saab 9000 aero upper and lower oil cooler lines from the oil cooler to the oil filter.
If you post this in the Classified section you would have better luck. Also are you looking for them used or are you looking for them new. If new I would recomend you try eeuroparts.com
Waay cheaper (and probably better!) to take your lines to a local hydraulic repair shop (where lines are built for construction & hydraulic equipment) and have your lines rebuilt.
I didn't even think of that Banman but that probably would be better. You could probably have them build you better ones also.
I've known this is a problem on the C900--galvanic corrosion caused by a steel hose fitting on an aluminum cooler--stupid farks! And they call themselves "born of aircraft" :ahh:
I'll have to see if the 9K suffers the same defect--I've written up my fixes for that on SC
