1 - 1 of 1 Posts
The earlier lamp is for cars without headlight wipers. The buckets are all the same. The lamp for cars with headlight wipers doesn't have the extra little bump on the top center of the lens. The wiper would hit that bump. You can use the earlier lamps on your car, but you either have to grind and polish off the bump with a diamond wheel, or cut a relief for the bump out of the rubber part of the headlight wiper blade. I've done both. Obviously, cutting the blade is easier, and less conspicuous.
The lenses are glass, so if you grind the nipple off, use plenty of water as you're doing it to keep them from cracking.
I'll reiterate what Adam said... get that CE registered if you haven't already.
1 - 1 of 1 Posts
