Do you see the tach jump when it turns over?
If not,
Crank Position Sensor.
If not,
Thanks for your help.What is the fuel pressure while it cranks?
Does it act up when it's hot/been driven prior?
SOUNDS like it could be the crank sensor - but could also be a failing fuel pump too.
Thanks for your help.Chances are a crank sensor will not cool off that quick to restart. I realized you said you didn't have a chance to really diagnose it. I might look at the fuel pressure regulater. It could be leaking causing no fuel pressure when you start it and a flooded condition at the same time.
Thank you for your help.Do you see the tach jump when it turns over?
If not,
After analyzing your advice/opinions/experience I took what I hope was a precautionary action. I replaced the crankshaft position sensor. I ordered one, paid for overnight delivery and installed it this afternoon.This is a mystery to me but I hope not to one of you has been through it or knows the systems better than I. The problem: Intermittent No-Start while Cranking Normally.
Without warning and without pattern (that I've noticed) the 2002 9-5 will crank but not start. Normally it starts within 1-3 seconds but ocassionally fails to start after 10 seconds of cranking. When it fails there is no attempt to "catch" (as if it had too much fuel). It is as if it has no spark or no fuel. Never at home, the cure has been is to wait 3 minutes and try again. It starts on the 2nd, 3rd, 4th or 5th attempt, waiting 3 minutes between each attempt. Never has if failed at a place or for a period where I could test for fuel or spark at the cyclinder.
The 9-5 has 125,000 miles and received new plugs and fuel filter at 120,000 inspection/maintenance. At about 110,000 I removed the alarm and did not replace it. This did not have any effect on starting.
I have reviewed the other posts but did not find any exactly on point. I am leaning toward fuel pump or check valve.
Any ideas?
I had t his same issue but the tach bounced a little but the car would not start turned out it was a broken fuel pump i installed a walbro 255 lph and she ran perfect. ironically now the problem still is there once in a while there is a long crank no start but now the needle dose not bounce so far this is always after i have driven, sometimes it starts right away even after a drive but after it sits for an hour it has a hard time starting. going to order a cps soon
