21 - 24 of 24 Posts
My 2007 9-3 2.0T Check engine light is on no other power car won't start nothing happens when key is inserted. All I can see is the check engine light. Issue started 3 days ago while I was detailing interior, battery died. Was able to put on charge car started no problems. Since then the when I go start the car the ignition will not turn, there is no familiar clicking when key inserted. After some playing would finally unlock car would start. However when go to turn off,key would stop at on position and acc power stays on, after some play key would turn off and come out. Twice seen message on SID remove key slightly turn wheel retry. Last night ignition would not turn now SID displays key not recognized contact dealer. Was told to replace key fob batt. And car batt. Replaced both, however when installed new car batt. Heard a strange buzzing or beeping for several seconds, now I have absolutely no power to anything. Key no longer works to even unlock doors. Only thing displayed is solid check engine light.
Not even close to being a mechanic so if anyone has any ideas as to what may be the cause I would greatly appreciate the help so when I get to dealer I can bring my own lube. Lol
It is better to call a professional and leave all troubles behind. But don't get scammed, nowadays you can find a lot of them on internet so ask for license and the price. When the price is too low, it can't be right.
9-3 Won't Start?
My 05 saab 9-3 won't start after driving it's happening from last week when i take negative terminal out off the battery wait for five second put it back again and starts can anyone tell me what's wrong with my Saab 9-3 why it's doing this
I have 2002 9-3 se turbo convertable with a very similar problem, Engine turns over, but not kick - no start. Battery voltage 12.46v should be good. High beams will not stay on, fog lights no light, turn signals no work, interior lights no come on, electric locks no worky, and 4 way flasher no flashy. I am analyzing.
so I was having the same problem as the one guy my 06 93 was stuck in the on position and we took apart the ignition box I got some isopropyl alcohol and cleaned the mother board and components put her back together and she turned over thank the heavens! so if your a coffee drinker like me try to keep your coffee away from the center console lol ahhh that was horrible not mentioning its 100 degrees outside lol
21 - 24 of 24 Posts
