If you aren't getting fuel to the rail, the pump isn't working, either its not pumping any fuel, or its not being turned on by the ECU/fuel pump relay. If you bypass the fuel pump relay and power the pump directly do you get fuel at the rail?
Paul
If you aren't getting fuel to the rail, the pump isn't working, either its not pumping any fuel, or its not being turned on by the ECU/fuel pump relay. If you bypass the fuel pump relay and power the pump directly do you get fuel at the rail?the pump works fine and the injectors are pumping but everything else is dry..what can it be?
