Hi!
Looking at a 6 puck clutch disc, I see the springs are covered by a plate (curved over the springs, like a hutch-back).
This plate is fixed on the disc with 6 bolts.
My dilemma is: should I cut the bolts and take off the plate, thus freeing the springs, or the disc goes in as it is?
As a side note, no1 ever used such a disc on a Saab around here, so no1 knows
Also, due to bad handling, the ferrodos on the disc have been slightly chipped/broken, on the edge, as seen in the attached pics. Would this disc still work on the car, eventually machining/grinding the edges prior to the mount, or the disc is good for garbage?
A good technical answer will be very appreciated!
Thanks for help!
Thanks for help!
