2001 Saab 9-3 exaust smoke
30K views 64 replies 11 participants last post by  Unreal2004
Could be a head gasket. And if it's been run too much like that, it could make the motor have some bad sounds. My friend bought a 900 with a bad HG that killed the motor. Sounded about like yours does before we pulled the motor out and put a new one in...
I think you need a new motor...that's a loud knock.
That crossed my mind, wouldn't that show some pretty noticeable loss in compression in at least one cylinder though?
Would there be a pretty distinct sign on one or more of the sparkplug(s)?
Not really sure to be honest, but what does the oil look like? Milky brown?
Also, a turbo would be more of bluish white smoke. That's white white smoke, and there is smoke coming from the oil filler cap, not a sign of a turbo failure.
I always thought the wiring harness was different between T5 and T7, and that the ECU was as well. When we put a motor in my friends '98 I was told only to get a T5 (B204) motor form '94-'98.
Baldsaab, did you have to rewire it?
