First the lock can stick it doe spop up a little, spray it with WD40 or lock lube
Regarding the noise, it sounds like you are hearing the Auto recircualte of the Automatic Climate control. It will set the car's vent to close at low speed when you are stopped in traffic or at a light after traveling at speed.
You can set it off and control it manually if you want and the noise is bothering you. Look in your manual I forget right now its beena while. I did, but was more worried that it woudl break and I did not care so much about having it do that all the time, I figured i could when I wanted it to just press the button
