Means of contact: PM or Phone #603-391-1409
Price: $2,500
Description: ****1991 9000 Turbo, 97,XXX Original Miles, 5 Speed Manual, Tan Heated Leather Interior, 2nd Owner, Clean Title, Very Clean car originally from the south west, NO RUST ANYWHERE. Has dash top crack, Needs headliner re-upholstered(already removed)****
*NEEDS AN ENGINE OR COMPLETE REBUILD OF CURRENT MOTOR. DOES RUN & DRIVE CURRENTLY(WILL NEED TO BE TOWED UPON PICKUP). FOUND METAL IN OIL PAN. HAS 6PSI OF OIL PRESSURE WHEN UP TO TEMP.
*VERY SOLID ORIGINAL TRANSMISSION W. FLUID DRAIN PLUG(never saw more than 14psi or stock pressure)
Drive-train & Suspension Modifications:
-Complete clean T5 Swap, ECU is running a stage 1 Mike D tune.
-TD04 19T Freshly Rebuilt(0 miles)
-Bosch GREEN GIANT Injectors
-NEW ETS Intercooler(0miles)
-NEW Stg II Clutch Disc(0miles)
-NEW Pressure Plate(0 miles)
-NEW Slave Cylinder
-Lightened Flywheel (-6lbs)
-NEW Complete CV AXLES
-Bilstein HD Shocks & Struts
-B&G Lowering Springs
-SAS Front & Rear Sway Bars
-NEW Strut Mounts
-JT 3'' Downpipe and Exhaust w. 3'' Race Cat & Magnaflow muffler.
-AC Delete w. Short Belt.
-Forge Bypass Valve
-Open Air Intake w. K&N Filter
MORE:
The Interior has a custom wood grain overlay on dash and center console. The Leather(front & back) is in near mint condition and has no cracks or rips. Everything works as it should.
Has double gauge pod in center console w. VDO OIL PRESSURE & BOOST Gauges.
New speakers all around, I will include the pioneer double din touch screen headunit w. bluetooth and Navigation or pull this and include the original equipment that came with the car. It is wired for a subwoofer & amplifier.
*There are a bunch more new parts and stuff included w. the car that I can get into further detail with a serious buyer.
I have owned this car for 5 years and have known it since the odometer read 60,000 miles. It is sadly time to move on. I have neither the facilities or means to keep funding this car. My loss is your great gain.
The car will remained covered and parked until it find's a new home. I am in no hurry to sell but motivated.
Pictures:
Price: $2,500
-NEW Slave Cylinder
-NEW Strut Mounts
-Forge Bypass Valve
MORE:
Pictures:
