Easy Peasy, either use the older manifold ( intake) , and charge air pipe with your sensors or if you get the newer engine with throtle body and charge air pipe, use that and rewire all the sensors
If possible, get the intake and throttle body WITH the 04 engine. Biggest change in the pcv system is the huge port in the 04+ throttle body (which draws directly from the oil trap instead of the tiny vacuum hose from the valve cover). Using the older pcv system negates the benefits of using a 04+ engine
