Maryland Inspection ......... - The Saab Link Forums
Go Back   The Saab Link Forums > Area Club Forums > WASSAAB > WASSAAB General Information
WASSAAB General Information General information pertaining to the Washington DC Saab Club
Old 03-18-2011, 09:44 AM   #1
LarryM's Avatar
This state so sucks for inspection ! Had multiple failures today, all of which were legal in RI ! First was the E-codes (I know, not DOT approved). Next was the JT 3" exhaust - seems the exhaust can't be any larger diameter than the stock system. Next up was my seat - it's set back 3" on 1/4" steel frame that uses the OEM mounting bolts. Nor the Momo steering wheel - seems that it somehow modifys the steering column ?
So now I need to find an interim set of headlights to get through inspection, not to mention moving the seat, getting a stock steering wheel, and replacing the exhaust ...........
WTF ! !
LarryM is offline
Old 03-18-2011, 10:03 AM   #2
oliversexpedition's Avatar
I'll trade for the e-codes! If you need to borrow a set, let me know. Exhaust should be legal, especially if it was offered as a "stock" item.
Seats and steering wheel, same thing. It needs to pass at time T.
--Oliversexpedition
ETA: Md inspections suck, but its a one time, except emissions.
WTF ! !
99 9-5 Wagon
01 9-5 Sedan
99 9-5 Wagon parting out
94 C900 Vert - Sold
94 325i Vert
oliversexpedition is offline
Old 03-20-2011, 09:25 AM   #3
Rudedog's Avatar
You need to go to a different station. That one must really be under the gun. The exhaust should be "OK". I didn't remember the seat being a checklist item. The steering wheel may be an issue because you deleted an airbag.
RG Rude
WASSAAB member
1997 900SE Talladega (SQR stage 4)
2006 9-3SS Aero
Rudedog is offline
Old 03-21-2011, 08:43 AM   #4
They probably looked at you, then the car, then said, "this guy has got to be the most obvious undercover agent".
Old 03-22-2011, 01:20 AM   #5
LarryM's Avatar
Maybe it was the two backup guns ......... But seriously, I installed a set of headlights, and factory steering wheel (courtesy of Frank) and went back yesterday morning to meet the state trooper from Maryland State Inspections. According to regulations, the exhaust will fail because it's a larger diameter than the stock system. The air bag should not be an issue due to the age of the car. The steering wheel failed because I had "modified" the steering column. I don't see how installing a different steering wheel counts as "modifying" the steering column, but then, I do wear pretty thick glasses .......
But we are looking at a house out in Lovettsville, Va this weekend !
LarryM is offline
Old 03-24-2011, 01:59 AM   #6
LarryM's Avatar
I'm almost legal ! Took the car to Lann's Service yesterday (as reccomended by Brewer's Saab). Still failed on the exhaust, but only because I have a leak. The bottom seam of the front muffler is rusted out - from the inside ! This on a JT system that was porcelain coated. So once I replace that muffler, I'll be good to pass inspection - just need to find a suitable replacement, and duplicate the hangers and piping .......
LarryM is offline
Old 03-25-2011, 07:06 AM   #7
LarryM's Avatar
No joy on just replacing that one muffler - and the rear muffler will also need to be replaced. I looked at Jetex and BSR, but there's a 2-3 week lead time, same with another JT. I only have til 6 April - so Monday morning I'm off to Maryland Performance exhaust (Performance Exhaust Maryland -- MBS is your Maryland source for custom performance exhaust).
They will make me 2 1/2" stainless system for the same price as the JT .......
I'll post pictures when it's done !
LarryM is offline
Old 03-25-2011, 01:09 PM   #8
Used a guy in winchester, he can fab up to 3" stuff, we cut in a 3 cat into my system. Maybe he can replace both mufflers?
99 9-5 Wagon
01 9-5 Sedan
94 C900 Vert - Sold
94 325i Vert
Old 03-25-2011, 10:22 PM   #9
Rudedog's Avatar
Sweet. When can I come by and look?
RG Rude
WASSAAB member
2006 9-3SS Aero
Rudedog is offline
Old 03-26-2011, 06:22 AM   #10
LarryM's Avatar
Randy, we might be living closer to you soon, we're looking at a house in Lovettsville, VA later today ........
My current work schedule is Mon => Thurs, 10:00 PM - 8:00 AM
LarryM is offline
Old 03-26-2011, 04:47 PM   #11
Rudedog's Avatar
Lovettsville is SWEET! I'm off weekdays till 04/17.
RG Rude
WASSAAB member
2006 9-3SS Aero
Rudedog is offline
Old 03-26-2011, 05:48 PM   #12
Talladega900's Avatar
Nice! I used to live in Purcellville. Lovettsville is really nice! Good luck with the house hunting! (And the inspection).
Jim Miller
'91 900 Turbo SE Convertible
'93 900 Turbo CE #116, modified
'02 9-5 Aero SportWagon, MT
'06 GTO, modified
'08 9-7X 6.0 Aero. The fastest stock Saab I've owned, bar none.
Talladega900 is offline
Old 03-26-2011, 06:40 PM   #13
LarryM's Avatar
The house we saw today was pretty nice - but the garage is not as big as my current garage (27' x 22'). But it's the best house we've seen so far ...
LarryM is offline
Old 03-30-2011, 01:24 PM   #14
Rudedog's Avatar
Surely you have a "fine adjustment tool" which it what the trim carpentry business I helped called a sledge hammer available. Don't you?
RG Rude
WASSAAB member
2006 9-3SS Aero
Rudedog is offline
Old 03-30-2011, 07:44 PM   #15
LarryM's Avatar
I have several "fine adjustment" tools, in various weights (sizes ?) . But this would still be a rental house, so no permanent adjustments - still looking for the suitable garage - with a house attached , of course !
LarryM is offline
You may not post new threads
You may not post replies
