Submission For AUGUST'S SAAB OF THE MONTH - The Saab Link Forums
Go Back   The Saab Link Forums > Saab Of The Month > SOTM Submissions & Voting
SOTM Submissions & Voting Submit your car for voting & vote for your favorite Saab.
Old 07-07-2013, 06:15 AM   #1
Greek Mod
grkguy89's Avatar
The rules are posted in the sticky in the main section for SOTM Submission & Voting
(here's the link just in case; SOTM, Rules and other need to knows.)
Open for entrants!!!! Will close on the 25th
follow this template
***EXAMPLE***
The Silver Sled (1988 900 Aero)
Specifications
Engine
Brand new Saab B202 2.0 Litre 16 valve crate engine (installed November 2010)
Rebuilt Bosch distributor
Stock Bosch electronic ignition
SPG9 AID (Advance Ignition Diaphragm) with timing at 20˚BTDC
Bougnicord spark plug leads
NGK BCP7EV plugs
Aquamist 1S water Injection using 0.9mm injector
Aquamist DDD (digital dash display) for water injection output
Crank case ventilation catch-can
Exhaust
2.5 inch from cat converter back with hi-flow racing cat
4 inch chrome semi-oval tip
Hi-flow dynomax stainless steel muffler and rear resonator
3 inch JSP stainless steel split down pipe off turbo to cat
Turbo
Mitsubishi TE-05 16G: with 16G compressor wheel with 10˚ clipped vanes, upgraded thrust and is rated as a 300HP turbo
Wastegate running 7psi base boost
Stage 2.5 SPG9 APC running to 18psi boost
Jak Stoll Performance Talon high-flow side mount intercooler
8 inch Davies Craig thermo pull fan mounted on reverse side of intercooler with manual switch inside cabin
Saab C900 1990+ aluminium turbo intercooler ducts
Stratmosphere Forge bypass valve
K&N filtercharger
Plastic intercooler top air dam
Fuel System
Bosch 3.0 BAR fuel pressure regulator
Trionic 5 34lb injectors
Jak Stoll Performance Stage 2 ECU chip
Fuel pressure gauge situated in-line on fuel rail
Suspension
Stock Saab Aero springs and shocks
Stock Saab Aero road handling kit including front and rear sway bars
Polyair inflatable air bags inside rear springs
Wheels & Tyres
16" x 6.5" Saab Super Aero rims
Goodyear Revspec Ducaro 205/50/16 tyres
Other
Stock Saab Aero factory whaletail
Saab Aero vent covers (factory colour coded silver to match duco)
AutoMeter 30"hg to 30psi boost guage
AutoMeter air/fuel ratio guage
Saab factory rear decor panel
SaabSavior short shifter
Saab Momo leather steering wheel
3.5mm blue silicon vacuum hose
Saab Aero original Alpine surround sound 5 speaker stereo
Aero kit factory colour coded silver to match duco
Output
Estimated 190kW (250hp) at front wheels (need to do another dyno once new crate engine is run in)
1 PICTURE!!!!
Current Activity: Moderating
grkguy89 is offline
Old 07-10-2013, 07:58 AM   #2
Greek Mod
grkguy89's Avatar
The Silver Pig (1997 900SE)
Specifications
Engine
B204 block and head
B205 Wossner Pistons
B205 rods
Balance chain delete
ARP Head studs
O-ringed Block
NGK plugs
Poly mounts
Exhaust
3" Top mount downpipe
3" cat back exhaust with Vibrant resonator and rear muffler
(Both fabricated and welded by yours truly)
EWG screamer pipe
Turbo
Holset HX35 7 blade with 9cm^2 exhaust housing
C9000 T3 exhaust manifold
Custom up-pipe with EWG
Godspeed 44mm EWG
Synapse Synchronic BOV with anti-stall kit
4" Intake
3.5" thick FMIC
Fuel System/Management
Walbro 255 fuel pump
Siemens Deka 60# injectors
T5suite Stage 7 (about to be custom tuned by yours truly)
4Bar Map sensor
SnowPerformance Stage 2 Water/Methanol Injection
Suspension
KYB shocks ans struts
Front: Vogtland
Rear: Custom coils
grkguy's 6-point
grkguy's 2-point hatch brace
double stacked and welded rear ARB
Wheels & Tyres
SSR Type C 17x8.5
offset F: 18 R: 13
215/45R17 Micheline Pilots
Purple lug nuts
Other
Gs short shifter
Prosport Evo boost gauge -30-35psi
AEM UEGO wideband A/F gauge
Glowshift oil temp gauge
Glowshift oil pressure gauge
Pioneer Stereo
Kenwood speakers
Rockford Fosgate P3 12" sub in a ported box
Bucket seats
Projector headlights with HID
THULE roof rack, and fairing
Output
Equal to the gravitational pull of a VY Canis Majoris
Probly missing more info, just cant think now
grkguy89 is offline
Old 07-12-2013, 08:48 AM   #3
Greek Mod
grkguy89's Avatar
Seriously, no one else?
grkguy89 is offline
Old 07-12-2013, 09:04 AM   #4
ninehundredt's Avatar
Any better pictures of your car (something within 25 feet of it)?
ninehundredt is offline
Old 07-12-2013, 09:06 AM   #5
Wagon Shaggin'
Saabeh's Avatar
The Shaggin' Wagon
Specifications:
2000 Saab 9-5 Aero Wagon 5spd
Engine:
Stage 1 Mike D Tune
Stock B235R
GS Intake
GS Poly Torque Arm
Aluminum BPV
Exhaust:
Stock (for now)
Turbo:
TD04 15t
Wheels & Tires:
18" ASA AR1
Powder coated Matte Black
Black Chrome wheel bolts
Carbon Fiber Center caps
Kumho Ecsta LE Sport 225/40-18
Other:
1999-2004 Mustang Mach 1 Chin Spoiler
Some Dog Leg Rust
Output:
~260bhp
Saabeh is offline
Old 07-12-2013, 10:47 AM   #6
Greek Mod
grkguy89's Avatar
none at the moment...
ill be doing a mini photo shoot here soon with some better closeups
grkguy89 is offline
Old 07-15-2013, 08:52 AM   #7
Marks9-3's Avatar
Not sure if I can compete with the orange wheels this month.
1999 9-3 'S'
Exterior Visual:
Saab Catalog Side Skirts
ITR Front Lip
SE Rear Lip
Viggen Spoiler
Smoked Side Turn Signals
Cleared Corner Lights
Wheels/Tires:
17" Saab Double Aero Rims (Evo II's)
Contenintal ExtremeContact DW (225/45/17)
Performance:
Genuine Saab 3" V2 SS DP and Center Section
Saab Sport Exhaust with 3" Tip
Genuine Saab Open Air Intake
TD04-19t turbo
630cc Injectors
3 Bar MAP sensor
JZW Stage 5ish
Forge 007 Twin Piston Blow off Valve (Silver)
Custom Front Mount Intercooler setup
T5 -> T7 BPC
Genuine Saab Short Shifter
Viggen Clutch and Pressure Plate
Brakes:
308mm front rotor upgrade with Hawk pads
300mm rear vented rotor upgrade
BF Goodridge Brake Lines Front/Rear
ATE SuperBlue Fluid
Suspension:
Koni Adjustable Front/Rear Shocks
Koni Sport Springs Front/Rear
MP Steering Rack Clamp and Brace
Genuine Saab 22mm Rear Sway Bar
Custom 2pt Subframe Brace
Genuine Saab Poly Front Inner Suspension Bushings
Genuine Saab Poly Front Outter Suspension Bushings
Genuine Saab Poly Front ARB Bushings
Genuine Saab Poly Steering Rod Bushings
Genuine Saab Poly Transmission Mount
Genuine Saab Poly Engine Mount
Other Upgrades:
Autometer Phantom II Boost Gauge
Autometer Phantom Wideband A/F Gauge
Short Belt Mod (No middle idler pulley or A/C Compressor)
'02 9-3 Anniversary Edition Black Leather Interior (stock was tan leather)
Saab Catalog Wood Shift Knob
Viggen/Aero Sport Steering Wheel
Installed Directed Audio s650 Components (doors)
Genuine Saab Black/Silver Billet Dead Pedal.
Output:
Never had it on the dyno yet, but JZW says it's north of 300whp
Marks9-3 is offline
Old 07-15-2013, 10:52 AM   #8
WSW
WSW's Avatar
99 Viggen
Specifications
Engine
Stock TD04
3" GS V2 Downpipe with Saabsport Catback
GS Intake
GS Intake Pipe
Hyperboost DV
ETS IC
3.5 FPR
BCB Stage 3 with OpenSID
Blue Silicone vac lines
GS engine mounts
A/C Removed cuz racecar
Suspension
Koni Struts and Shocks
Vogtland Lowering springs
Poly filled strut mounts
Poly control and stanchion arm bushings
Poly steering rod bushings
Poly arb bushings
GS Strut Brace
GS Steering rack clamp and brace
GS ARB
Wheels & Tires
18" Pontiac G6 Wheels with Saab center caps
225/45/zr18 General G-Max AS03 Tires
Brakes
Brembro slotted rotors
Hawk HPS pads
Goodridge stainless steel brake lines
Red painted calipers
Transmission
GS Trans mount
GS short shifter
Exterior
Retrofitted Projectors
20% tint all around
Clear corners
"Turbo" Vanity plate
Meshed grille
Carbon fiber emblems
TSL sticker representin'
Repainted bumpers,hood,spoiler and 3rd brake light
All jack covers intact
LaminX yellow fogs
LED license plate and sidemarker lights
Interior
Not worn to shit front seats!!
Oem carbon fiber dash and door pulls
Glowshift boost gauge in headlight switch spot
Solid armrest
JVC stereo
Pioneers in the dash, Infinity references in the doors and hatch
Other
Tons of maintenance, blood, money and sweat.. No tears just yet
Output
Not dynoed yet but typical stage 3 numbers
99 Viggen
04 9-5 Aero Wagon
WSW is offline
Old 07-18-2013, 09:37 AM   #9
soccerrplyr's Avatar
How do I post a larger pic like everyone else
Project 'Griffin' 2000 9-3 w/66k
Specifications
Engine
Stock TD04
Blue Silicone coolant hoses
Mp Performance Intercooler+
3.5 FPR with Cams awaiting install
Mike D Stage 2 with OpenSID
White Silicone vac lines
White powdercoated valve cover
GS oil/coolant polished caps
Polished intake
K&N filter
Suspension
Bilstien Struts and Shocks
Mp Performance Strut Brace
6pt brace
Wheels & Tires
17" BBS RkII Wheels, painted centers with red BBS center caps/valve caps
225/45/zr17 General Tires
Brakes
Brembro rotors
Akebono pads
Exterior
Euro Clear corners
Viggen Kit with all jack covers intact
Rooftop spoiler
"Griffin" Vanity plate and side badging
Black Pearl grille
Carbon fiber A,B,C pillars
Weathertech front/rear rain guards
LaminX yellow fogs
Clear sidemarker lights
Rear hatch debadged
Roof top antenna
Interior
2002 two tone turbo embossed leather/cloth swap
Carbon fiber dash
Carbon fiber door pulls
Autometer boost gauge in headlight switch spot
Solid armrest built into seat
Audiotroll stereo input
Infinity speakers all around
Saab projection under door lights
Custom Turbo Griffin door sills
Output
---Not dynoed yet
1999 9³ Stage 18t
2000 9³ Stage 19t
2005 CRV
soccerrplyr is offline
Old 07-18-2013, 10:14 AM   #10
WSW
WSW's Avatar
I use photobucket
99 Viggen
04 9-5 Aero Wagon
WSW is offline
Old 07-22-2013, 09:15 AM   #11
Averagers Racing Initiative "Stark Industries 900", $500 1995 900SE
Specifications
Engine
Viggen turbo
Unknown 3" downpipe
No Cat
Unknown 2.5" exhaust with Magnaflow muffler
Viggen intercooler
Genuine Saab Stage 4 ECU
Custom race intake
Spectre air filter
RFL knockoff BOV
Custom intercooler piping
Suspension
Stock struts and shocks
Unknown red lowering springs
Genuine Saab 22mm rear sway bar
Wheels & Tires
17" TSW Kyalami wheels, painted Iron Man gold
225/45/zr17 Hankook Ventus
Post race
-2 17" TSW wheels
+2 17" Sport Edition wheels and Primewell pz900
Brakes
Viggen front calipers
EBC yellows front and rear
Cryo treated front rotors
Brembo rear rotors
Exterior
Vinyl, lots of it
Gold racing stripes
Gold stock spoilter
Iron Man mask
Interior
Corbeau racing seat
RJS racing 5 point harness
1.75" DOM roll cage
Cage padding
Stripped interior
Iron Man copilot zip tied to dash
Output
---Not dynoed yet, but fastest car on the straightway
Icarus is offline
Old 07-22-2013, 09:17 AM   #12
Wagon Shaggin'
Saabeh's Avatar
I'm never going to win one of these unless I get pity votes.
Saabeh is offline
Old 07-22-2013, 10:15 AM   #13
rarelibra's Avatar
Send a message via Yahoo to rarelibra Send a message via Skype™ to rarelibra
Storsjöodjuret (2004 9-5 Arc 2.3T)
Specifications
Engine
90.5mm Wossner Pistons
T5 cams
ARP Head studs
Stainless steel exhaust manifold and turbo studs
Ported, polished, and balanced (http://s693.photobucket.com/user/pho...?sort=3&page=2)
NGK 7 plugs
GS poly mount
Maptun silicone hoses (intercooler and coolant)
Swedish DO88 silicone MAF to cobra hose
Exhaust
3" JT full exhaust
Powerflex exhaust hangars
Turbo
TD04-19t (#6)
ETS IC
GS T7 Cobra
Forge recirc valve w/red spring and 2 spacers
Maptun air filter
3.5 bar Bosch FPR
Suspension
Koni FSDs
Aero springs
SAS 25mm sway bars
Moog sway links and tie rods
Maptun strut tower brace
Powerflex street series bushings all around
Wheels & Tyres
17" Aero EVO 5-spoke wheels
Michelin Pilot A/S Sport Plus 225/45 ZR17
Viggen vented discs w/Hawk pads
GenuineSaab custom billet aluminum griffin center caps
StateofNine chrome lug caps
chrome valve stem caps
Other
GS aluminum dead pedal
Berber Saab floor mats
Hirsch mesh grille
Hirsch spoiler
FocusLima black griffin badges
Nordicspeed Euro corners
red Hella supertones
Output
currently Maptun stage 4 315hp ECU (upgrading to a stage 5 ECU soon)
*official dyno to be done on Friday morning at SOC
i don't think a c900 has sold for 28k since the day one left the dealership new.
rarelibra is offline
Old 07-22-2013, 10:58 AM   #14
Greek Mod
grkguy89's Avatar
i feel the same way for this month
grkguy89 is offline
Old 08-26-2013, 03:33 PM   #15
Svenska94Aero's Avatar
Send a message via AIM to Svenska94Aero
Originally Posted by soccerrplyr View Post
Oh hey, I recognize that photo
1973 99 EMS - Big plans
1990 900 SPG - Go-kart with a Holset
1995 9000 CS - PITA
Svenska94Aero is offline
