Submission For JULY'S SAAB OF THE MONTH - The Saab Link Forums
Go Back   The Saab Link Forums > Saab Of The Month > SOTM Submissions & Voting
SOTM Submissions & Voting Submit your car for voting & vote for your favorite Saab.
Old 06-03-2013, 12:06 PM   #1
Greek Mod
grkguy89's Avatar
The rules are posted in the sticky in the main section for SOTM Submission & Voting
(here's the link just in case; SOTM, Rules and other need to knows.)
Open for entrants!!!! Will close on the 25th
follow this template
***EXAMPLE***
The Silver Sled (1988 900 Aero)
Specifications
Engine
Brand new Saab B202 2.0 Litre 16 valve crate engine (installed November 2010)
Rebuilt Bosch distributor
Stock Bosch electronic ignition
SPG9 AID (Advance Ignition Diaphragm) with timing at 20˚BTDC
Bougnicord spark plug leads
NGK BCP7EV plugs
Aquamist 1S water Injection using 0.9mm injector
Aquamist DDD (digital dash display) for water injection output
Crank case ventilation catch-can
Exhaust
2.5 inch from cat converter back with hi-flow racing cat
4 inch chrome semi-oval tip
Hi-flow dynomax stainless steel muffler and rear resonator
3 inch JSP stainless steel split down pipe off turbo to cat
Turbo
Mitsubishi TE-05 16G: with 16G compressor wheel with 10˚ clipped vanes, upgraded thrust and is rated as a 300HP turbo
Wastegate running 7psi base boost
Stage 2.5 SPG9 APC running to 18psi boost
Jak Stoll Performance Talon high-flow side mount intercooler
8 inch Davies Craig thermo pull fan mounted on reverse side of intercooler with manual switch inside cabin
Saab C900 1990+ aluminium turbo intercooler ducts
Stratmosphere Forge bypass valve
K&N filtercharger
Plastic intercooler top air dam
Fuel System
Bosch 3.0 BAR fuel pressure regulator
Trionic 5 34lb injectors
Jak Stoll Performance Stage 2 ECU chip
Fuel pressure gauge situated in-line on fuel rail
Suspension
Stock Saab Aero springs and shocks
Stock Saab Aero road handling kit including front and rear sway bars
Polyair inflatable air bags inside rear springs
Wheels & Tyres
16" x 6.5" Saab Super Aero rims
Goodyear Revspec Ducaro 205/50/16 tyres
Other
Stock Saab Aero factory whaletail
Saab Aero vent covers (factory colour coded silver to match duco)
AutoMeter 30"hg to 30psi boost guage
AutoMeter air/fuel ratio guage
Saab factory rear decor panel
SaabSavior short shifter
Saab Momo leather steering wheel
3.5mm blue silicon vacuum hose
Saab Aero original Alpine surround sound 5 speaker stereo
Aero kit factory colour coded silver to match duco
Output
Estimated 190kW (250hp) at front wheels (need to do another dyno once new crate engine is run in)
1 PICTURE!!!!
Current Activity: Moderating
grkguy89 is offline
Old 06-03-2013, 04:31 PM   #2
TheSaabNinja's Avatar
Worth a shot!
Pepper(1998 NG900 SE Turbo 5 Door)
Specifications
Engine
Stock B204L 2.0 Turbocharged Inline 4
Exhaust
Stainless Steel Saab Sport Exhaust system
Stock Downpipe
Saab Sport Exhaust Muffler Tip wrapped in Carbon Fiber
Turbo
Stock Garrett t25 (have a Mitsubishi TD04 15T waiting to be installed)
Genuine Saab Open Air Intake
Stock Saab Blow Off Valve (yes, she does Moo)
Viggen Front Mount Intercooler
Fuel System
Mike D's Stage 2 ECU Road Tune
Suspension
Stock...for now. (Planning to go bagged)
Wheels and Tires
16" Talladega Super Aeros
Sumitomo All Seasons 205/55/R16
Other
Lamin-x Yellow Tinted Foglights
Clear Corner Lights
OEM Wood Grain Dash (for the sleeper effect )
OEM Saab 9-5 Aero Sports Grip Steering Wheel
Various Go Fast Stickers around the world including :
"Made In Trollhattan"
"Saab Nuts!"
" You Like This."
Gripen
"Mike D Tuned"
"Saab Rally Moose"
Saab Club of San Diego
2001 9-5 Aero Clone Stage 1
2001 9-3 Base 15t swapped
TheSaabNinja is offline
Old 06-03-2013, 06:10 PM   #3
Marks9-3's Avatar
1999 9-3 'S'
Exterior Visual:
Saab Catalog Side Skirts
ITR Front Lip
SE Rear Lip
Viggen Spoiler
Smoked Side Turn Signals
Cleared Corner Lights
Wheels/Tires:
17" Saab Double Aero Rims (Evo II's)
Contenintal ExtremeContact DW (225/45/17)
Performance:
Genuine Saab 3" V2 SS DP and Center Section
Saab Sport Exhaust with 3" Tip
TD04-19t turbo
630cc Injectors
3 Bar MAP sensor
JZW Stage 5ish
Forge 007 Twin Piston Blow off Valve (Silver)
Custom Front Mount Intercooler setup
T5 -> T7 BPC
Genuine Saab Short Shifter
Viggen Clutch and Pressure Plate
Brakes:
308mm front rotor upgrade with Hawk pads
300mm rear vented rotor upgrade
BF Goodridge Brake Lines Front/Rear
ATE SuperBlue Fluid
Suspension:
Koni Adjustable Front/Rear Shocks
Koni Sport Springs Front/Rear
MP Steering Rack Clamp and Brace
Genuine Saab 22mm Rear Sway Bar
Custom 2pt Subframe Brace
Genuine Saab Poly Front Inner Suspension Bushings
Genuine Saab Poly Front Outter Suspension Bushings
Genuine Saab Poly Front ARB Bushings
Genuine Saab Poly Steering Rod Bushings
Genuine Saab Poly Transmission Mount
Genuine Saab Poly Engine Mount
Other Upgrades:
Autometer Phantom II Boost Gauge
Autometer Phantom Wideband A/F Gauge
Short Belt Mod (No middle idler pulley or A/C Compressor)
'02 9-3 Anniversary Edition Black Leather Interior (stock was tan leather)
Saab Catalog Wood Shift Knob
Viggen/Aero Sport Steering Wheel
Installed Directed Audio s650 Components (doors)
Genuine Saab Black/Silver Billet Dead Pedal.
Output:
Never had it on the dyno yet, but JZW says it's north of 300whp
Marks9-3 is offline
Old 06-19-2013, 08:48 AM   #4
9ryan3viggen's Avatar
1999 Saab 9-3 Viggen
ENGINE
b235R Brew City Boost stage 2+ and stage 3 one the way. 313 ft lbs at the wheels
and 220 hp at the wheels
GS Trans mount
Exhaust
GS 3" Downpipe with race cat. 2.5" all the way back resonator delete stock Viggen muffler - sounds great!
Turbo
Stock turbo. Krona cobra inlet pipe with a forge BPV
Fuel System
Stock for now will be doing a FPR in the near future when I do stage 3
Brakes
Akibono pads Viggen rotors.
Suspension
New control arms and tie rods inners and outers
Poly control arm bushings
Wheels & Tires
18" Elbrus I06 with General as03 tires
17" stock Viggen wheels - being refinished
Other
12" subwoofer in the trunk for some good sound. New viggen emblems and saab emblems. Smoked side markers and some Brew City Boost bling.
9ryan3viggen is offline
Old 06-19-2013, 11:54 AM   #5
Wagon Shaggin'
Saabeh's Avatar
The Shaggin' Wagon
Specifications:
2000 Saab 9-5 Aero Wagon 5spd
Engine:
Stage 1 Mike D Tune
Stock B235R
GS Intake
GS Poly Torque Arm
Aluminum BPV
Exhaust:
Stock (for now)
Turbo:
TD04 15t
Wheels & Tires:
18" ASA AR1
Powder coated Matte Black
Black Chrome wheel bolts
Carbon Fiber Center caps
Kumho Ecsta LE Sport 225/40-18
Other:
1999-2004 Mustang Mach 1 Chin Spoiler
Some Dog Leg Rust
Output:
~260bhp
Saabeh is offline
Old 06-20-2013, 06:02 PM   #6
WSW
WSW's Avatar
99 Viggen
Specifications
Engine
Stock TD04
3" GS V2 Downpipe with Saabsport Catback
GS Intake
GS Intake Pipe
Hyperboost DV
ETS IC
3.5 FPR
BCB Stage 3 with OpenSID
Blue Silicone vac lines
GS engine mounts
A/C Removed cuz racecar
Suspension
Koni Struts and Shocks
Vogtland Lowering springs
Poly filled strut mounts
Poly control and stanchion arm bushings
Poly steering rod bushings
Poly arb bushings
GS Strut Brace
GS Steering rack clamp and brace
GS ARB
Wheels & Tires
18" Pontiac G6 Wheels with Saab center caps
225/45/zr18 General G-Max AS03 Tires
Brakes
Brembro slotted rotors
Hawk HPS pads
Goodridge stainless steel brake lines
Red painted calipers
Transmission
GS Trans mount
GS short shifter
Exterior
20% tint all around
Clear corners
"Turbo" Vanity plate
Meshed grille
Carbon fiber emblems
TSL sticker representin'
Repainted bumpers,hood,spoiler and 3rd brake light
All jack covers intact
LaminX yellow fogs
Interior
Not worn to shit front seats!!
Oem carbon fiber dash and door pulls
Glowshift boost gauge in headlight switch spot
Solid armrest
JVC stereo
Pioneers in the dash, Infinity references in the doors and hatch
Other
Tons of maintenance, blood, money and sweat.. No tears just yet
Output
Not dynoed yet but typical stage 3 numbers
99 Viggen
04 9-5 Aero Wagon
WSW is offline
Old 06-20-2013, 06:54 PM   #7
stig's Avatar
1996 9000 Aero, 273k miles and climbing.
Exterior Visual:
E-code headlights
E-code corner lights
Smoked fender markers
Wheels/Tires:
16" Aero's in dire need of refinishing
205/55/16 free snows
Performance:
Group9 3" downpipe
Locally made 3"/2.5" cat back
GS Open Intake
EIIIUSA FMIC
Forge BOV
T7 BPC conversion
T5Suite Stage 3
Brakes:
EBC Redstuff pads
ATE SuperBlue Fluid
Suspension:
B&G springs
SAS swaybars
Other Upgrades:
Cheapo boost gauge in a-pillar pod
A/C delete
Output:
Never dyno'd. Standard issue stage 3 numbers...
'96 Miata - Simplify and add lightness
'96 9000 Aero - Complicate and add torque steer
stig is offline
Old 06-20-2013, 07:02 PM   #8
Cark's Avatar
I think Stig should win based on mileage... that shit is crazy!
08 9-5 Aero S/C
85 900 turbo - T5
Cark is offline
Old 06-22-2013, 08:44 AM   #9
justineffingp's Avatar
Project "JET LAG" (88 SPG)
Specifications
Engine
B202T
Trionic 5 Engine Management
JZW TUNE
Exhaust
Speedparts Tubular Header
3in Homemade Downpipe
2.5in stainless steel "Saab Savior" exhaust from DP Back
Tial MVS 38mm ewg Venting to atmosphere
Turbo
Gt3582r Ball Bearing turbo
Ebay FMIC with 2.5in piping
HKS ssqv
silicone vac lines
Fuel System
Siemens Deka 630cc/min Injectors
Bosch o40 fuel pump
Suspension
AFCO Adjustable springs all 4 corners
Tokico Shocks
Powerflex poly bushings all around
Wheels & Tyres
17x7 Black wheels
Hankook Ventus k110v12 evo 205 45 17
Other
Saab factory whaletail
Saab Airflow kit
Spec Stage 3 Clutch
Kurbads Short shifter
Brand New 140 mph speedo
Saab momo Steering Wheel
Tenzo racing bucket seats
Polk Audio Speakers/Sub and Aftermarket Head unit
Output
Unknown
Build Thread
https://www.saablink.net/forum/perfor...-900/54997.htm
justineffingp is offline
