Submission For APRIL'S SAAB OF THE MONTH - The Saab Link Forums
Go Back   The Saab Link Forums > Saab Of The Month > SOTM Submissions & Voting
SOTM Submissions & Voting Submit your car for voting & vote for your favorite Saab.
Old 03-06-2013, 03:30 PM   #1
Greek Mod
grkguy89's Avatar
The rules are posted in the sticky in the main section for SOTM Submission & Voting
(here's the link just in case; SOTM, Rules and other need to knows.)
Open for entrants!!!! Will close on the 25th
follow this template
***EXAMPLE***
The Silver Sled (1988 900 Aero)
Specifications
Engine
Brand new Saab B202 2.0 Litre 16 valve crate engine (installed November 2010)
Rebuilt Bosch distributor
Stock Bosch electronic ignition
SPG9 AID (Advance Ignition Diaphragm) with timing at 20˚BTDC
Bougnicord spark plug leads
NGK BCP7EV plugs
Aquamist 1S water Injection using 0.9mm injector
Aquamist DDD (digital dash display) for water injection output
Crank case ventilation catch-can
Exhaust
2.5 inch from cat converter back with hi-flow racing cat
4 inch chrome semi-oval tip
Hi-flow dynomax stainless steel muffler and rear resonator
3 inch JSP stainless steel split down pipe off turbo to cat
Turbo
Mitsubishi TE-05 16G: with 16G compressor wheel with 10˚ clipped vanes, upgraded thrust and is rated as a 300HP turbo
Wastegate running 7psi base boost
Stage 2.5 SPG9 APC running to 18psi boost
Jak Stoll Performance Talon high-flow side mount intercooler
8 inch Davies Craig thermo pull fan mounted on reverse side of intercooler with manual switch inside cabin
Saab C900 1990+ aluminium turbo intercooler ducts
Stratmosphere Forge bypass valve
K&N filtercharger
Plastic intercooler top air dam
Fuel System
Bosch 3.0 BAR fuel pressure regulator
Trionic 5 34lb injectors
Jak Stoll Performance Stage 2 ECU chip
Fuel pressure gauge situated in-line on fuel rail
Suspension
Stock Saab Aero springs and shocks
Stock Saab Aero road handling kit including front and rear sway bars
Polyair inflatable air bags inside rear springs
Wheels & Tyres
16" x 6.5" Saab Super Aero rims
Goodyear Revspec Ducaro 205/50/16 tyres
Other
Stock Saab Aero factory whaletail
Saab Aero vent covers (factory colour coded silver to match duco)
AutoMeter 30"hg to 30psi boost guage
AutoMeter air/fuel ratio guage
Saab factory rear decor panel
SaabSavior short shifter
Saab Momo leather steering wheel
3.5mm blue silicon vacuum hose
Saab Aero original Alpine surround sound 5 speaker stereo
Aero kit factory colour coded silver to match duco
Output
Estimated 190kW (250hp) at front wheels (need to do another dyno once new crate engine is run in)
1 PICTURE!!!!
Current Activity: Moderating
grkguy89 is offline
Old 03-06-2013, 05:00 PM   #2
soccerrplyr's Avatar
what happened to December, Jan, Feb or March?
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
soccerrplyr is offline
Old 03-06-2013, 06:52 PM   #3
VWSAABVT's Avatar
Who cares? Life still exists even after missing them.
stg 5 99 9-3 coupe
96 900se sold
VWSAABVT is offline
Old 03-06-2013, 10:02 PM   #4
Greek Mod
grkguy89's Avatar
me, school, work, trying to move out, failing at moving out, laptop screen dying, and sister moving to philly making work even more busy
grkguy89 is offline
Old 03-07-2013, 10:08 AM   #5
I do seeing as I already did a submission for one of the missing months and nothing came of it.
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
Old 03-07-2013, 10:08 AM   #6
Understandable
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
Old 03-16-2013, 11:40 AM   #7
Just bought it
2003 9-3se convertible
Everthing stock...........for now!
9-3vert is offline
Old 03-16-2013, 12:25 PM   #8
Svenska94Aero's Avatar
Send a message via AIM to Svenska94Aero
Guess this is my last chance to post it up before it is parted out and heads to scrap:
Svenska (or Project Death Star) - 1994 9000 Aero
Specifications
Engine
Engine replaced at 150k with a 78k longblock
Custom 3" intake with cone filter in drilled airbox
NGK BCPR7ES plugs
Rose Engineering aluminum PCV breather nipple
4mm Red silicone vacuum hoses throughout
A/C delete
Exhaust
BSR stainless cat-back exhaust
Turbo
Original Mitsubishi TD04-15t
Stage 2 T5-suite tune by Richard LaBarre
HKS SSQV Ver.1 blow-off valve
Fuel System
All stock
Suspension
Custom-built air ride, giving approximately 3/4" clearance from ground to front subframe:
-AirLift Universal front struts, kit 75561 long stroke bellows-style bags with custom hub knuckle brackets and top mounts
-Firestone 7076 Inverted-sleeve rear bags with custom machined top and bottom mounts
-VIAIR 400c compressor
-Accuair 5-gallon raw aluminum skinny tank
-Accuair EXO mount system
-EAI 7-switch controller
-8 SMC valves allowing each corner to be controlled separately
-145psi tank pressure switch
-Clear water trap
-EXTA dual-needle gauges
Poly control arm bushings
Wheels & Tires
16" x 6.5" Saab Griffin wheels, Plastidipped white
Bridgestone Blizzak 185/55-16 winter tires
Other
E36 BMW 3-series DDM euro headlight conversion with 5000k low beams
JVC El Kameleon black-panel head unit
Viggen-style roof mounted antenna
VDO boost gauge mounted in place of dash clock
OE Saab tinted sunroof wind deflector
Weathertech window deflectors
Black suede headliner & pillars
Custom aluminum shift knob
Reverse-lockout delete
Custom aluminum shift boot collar
Goodridge stainless steel braided brake lines
New rear brake calipers
New EMPI CV axles
New hood
New OE clutch master cylinder
Color-matched side mirrors
Color-matched and meshed grille
Clear corner signals
Debadged hatch
Smoked side repeaters
Low side-mount license plate
Aero vanity plate
232,000 miles
Output
Estimated 245hp at front wheels, limited due to exhaust and wearing clutch
So long, old friend.
1973 99 EMS - Big plans
1990 900 SPG - Go-kart with a Holset
1995 9000 CS - PITA
Svenska94Aero is offline
