Submission For NOVEMBER'S SAAB OF THE MONTH - The Saab Link Forums
Go Back   The Saab Link Forums > Saab Of The Month > SOTM Submissions & Voting
SOTM Submissions & Voting Submit your car for voting & vote for your favorite Saab.
Old 10-20-2012, 05:40 AM   #1
Greek Mod
grkguy89's Avatar
The rules are posted in the sticky in the main section for SOTM Submission & Voting
(here's the link just in case; SOTM, Rules and other need to knows.)
Open for entrants!!!! Will close on the 25th
follow this template
***EXAMPLE***
The Silver Sled (1988 900 Aero)
Specifications
Engine
Brand new Saab B202 2.0 Litre 16 valve crate engine (installed November 2010)
Rebuilt Bosch distributor
Stock Bosch electronic ignition
SPG9 AID (Advance Ignition Diaphragm) with timing at 20˚BTDC
Bougnicord spark plug leads
NGK BCP7EV plugs
Aquamist 1S water Injection using 0.9mm injector
Aquamist DDD (digital dash display) for water injection output
Crank case ventilation catch-can
Exhaust
2.5 inch from cat converter back with hi-flow racing cat
4 inch chrome semi-oval tip
Hi-flow dynomax stainless steel muffler and rear resonator
3 inch JSP stainless steel split down pipe off turbo to cat
Turbo
Mitsubishi TE-05 16G: with 16G compressor wheel with 10˚ clipped vanes, upgraded thrust and is rated as a 300HP turbo
Wastegate running 7psi base boost
Stage 2.5 SPG9 APC running to 18psi boost
Jak Stoll Performance Talon high-flow side mount intercooler
8 inch Davies Craig thermo pull fan mounted on reverse side of intercooler with manual switch inside cabin
Saab C900 1990+ aluminium turbo intercooler ducts
Stratmosphere Forge bypass valve
K&N filtercharger
Plastic intercooler top air dam
Fuel System
Bosch 3.0 BAR fuel pressure regulator
Trionic 5 34lb injectors
Jak Stoll Performance Stage 2 ECU chip
Fuel pressure gauge situated in-line on fuel rail
Suspension
Stock Saab Aero springs and shocks
Stock Saab Aero road handling kit including front and rear sway bars
Polyair inflatable air bags inside rear springs
Wheels & Tyres
16" x 6.5" Saab Super Aero rims
Goodyear Revspec Ducaro 205/50/16 tyres
Other
Stock Saab Aero factory whaletail
Saab Aero vent covers (factory colour coded silver to match duco)
AutoMeter 30"hg to 30psi boost guage
AutoMeter air/fuel ratio guage
Saab factory rear decor panel
SaabSavior short shifter
Saab Momo leather steering wheel
3.5mm blue silicon vacuum hose
Saab Aero original Alpine surround sound 5 speaker stereo
Aero kit factory colour coded silver to match duco
Output
Estimated 190kW (250hp) at front wheels (need to do another dyno once new crate engine is run in)
1 PICTURE!!!!
Current Activity: Moderating
grkguy89 is offline
Old 10-22-2012, 11:54 AM   #2
Wagon Shaggin'
Saabeh's Avatar
The Penis Pump (2000 Saab 9-3 Viggen)
Engine:
Rebuilt B235R with perfect compression.
Stage 3+ Tune
3.5Bar FPR
Intake
Forge BPV
Exhaust:
3" Genuine Saab V2 Downpipe
2.5" Saabsport (< What how? You have a Viggen? OMG)
Suspension:
Koni Springs
Bilstein HD Shocks
Genuine Saab Steering Clamp and Brace
Genuine Saab 6 Point Subframe Brace
Genuine Saab 22mm ARB
Genuine Saab 3 point Hatch Brace
Wheels & Tires:
Stock bent Viggen wheels on Goodyear RS-A
Klingons for snow
Other:
Memphis Audio Powered Components
Kenwood Deck
Morimoto Mini H1 Bi-Xenon Retrofit
30% front tint 15% rear tint
Output:
about 300hp.
Vote for me because Saabeh is moderator.
Saabeh is offline
Old 10-22-2012, 01:22 PM   #3
k1llsh0rty's Avatar
The Black Bitch
(2000 5DR Viggen)
Specifications
Engine
DIY high-flow intake with heatshield, Forge BPV (black), Stg 1 tune
Exhaust
Saab Sport exhaust
Turbo
Stock turbo with DIY "King Cobra" inlet pipe
Fuel System
Stock
Suspension
GS inner and outer control arm poly bushings, GS ARB endlink bushings, GS 1" rear ARB, GS inner tie rod bushings, GS rear axle bushings, KYB GR2's all the way around, MP Performance rack clamp and brace and SPEC friction disc w/lightend stock flywheel
Wheels & Tyres
16 x 6.5 Saab five spoke plastidipped black
Other
fully debadged, DIY clear corners, Sylvania Silverstar "blue" bulbs in front signals, and color keyed/DIY mesh grill, repainted front bumper with texture strip smoothed and color-keyed, GG front and rear custom Viggen black and chrome emblems, LED license plate bulbs, OEM carbon fiber look dash, and real CF front door pulls, boost gauge mounted on dash.
Output
N/A
Originally Posted by Ironjoe
I'm sure you'll find that quite a few TSLers are well-equipped enough to service even your 3" downpipe.
k1llsh0rty is offline
Old 10-22-2012, 01:53 PM   #4
Cark's Avatar
Might have to commit to a vote for SAABEH already... since I took that picture
08 9-5 Aero S/C
85 900 turbo - T5
Cark is offline
Old 10-23-2012, 06:16 AM   #5
Wagon Shaggin'
Saabeh's Avatar
Hahaha the booty barge. I call BS on no rust holes!
Also, do you currently own this car? I think we made an amendment last time that you need to currently own it to compete.
Saabeh is offline
Old 10-23-2012, 07:22 AM   #6
Cark's Avatar
Ya, didn't wanna be the A hole, but I thought after last month, the "cars I used to own" thing got cleared up?
08 9-5 Aero S/C
85 900 turbo - T5
Cark is offline
Old 10-23-2012, 07:48 AM   #7
88SPG's Avatar
D'oh. Forgot about the "formerly owned" rule. Mods please delete my posts in this thread if possible. Sorry about that.
Current: '97 9000 Aero, '88 900 SPG (2x),
'87 900 S, '67 96 V4
Former: '97 9000 CS, '94 900 CV, '91 900 SPG,
'80 900 T, '79 900 EMS
88SPG is offline
Old 10-23-2012, 08:09 AM   #8
jk88's Avatar
You should make another thread about that car though, and please make it just as funny.
jk88 is offline
Old 10-23-2012, 09:36 AM   #9
We_sleigh's Avatar
Biorex (1999 9-3)
Go fast bits:
JZW stg 6 Custom Tune
ISIS rs3871r Turbo
ISIS Screamer Dump Elbow
Siemens Deka #60
Walbro 255
ATP 18psi Base Wastegate actuator
Custom 3 inch exhaust
borla Resonator
Precision FMIC
Custom Pipe Routing
AC delete
HKS ssqv
FlexaLite Oil Cooler
Jegs Oil Fittings and Lines
GS manifold Spacer
3 bar map
Ported Tb transition
Aesthetics:
Repainted TurboX Black
SE Skirts and rear lip
ITR mugen front lip
Tinted Yellow LaminX Fogs
Custom Valeo Projector Retrofit
BMW 7 Series Shrouds
6000k Headlights
Carbon Pillars
Hipster Burberry Totes-Adorbs Vinyl Wrapped Roof
Interior:
Viggen dash Fascia
Removed Rear seat
kenwood Head unit
Centerdash Mounted Glowshift Boost and AEM UEGO
Suspension:
New LCAs and TREs
Custom Coilovers built my myself
Bilstein Sports from MK1 GTi
Custom Sleeves and Springs (rides firm but not violent)
5x110-5x100 15mm Innovate Autosport Adapters
Motegi SP10 coated A deep red
Final front offset 15 rear 10.
Sent from my iPhone using AG Free
Photo wouldnt upload at first. Fail
File Type: jpg ImageUploadedByAG Free1351013874.159626.jpg (90.9 KB, 118 views)
We_sleigh is offline
Old 10-23-2012, 01:15 PM   #10
88SPG's Avatar
The Silver Bullet (1988 900 SPG)
Not a clone. An original 1988 SPG factory-painted silver for the US Market.
Still have original window sticker stating Silver/943M
Engine - All Stock
Exhaust
3 inch from manifold back
3 inch chrome semi-oval tip
Hi-flow Flowmaster stainless steel muffler
Cat delete (no vehicle inspections in Florida )
Suspension
500lb rear springs
Wheels & Tyres
16" x 6.5" Saab Aero rims
Kuhmo 205/50/16 tires
Other
Saab Aero vent covers (factory color coded silver)
Badge delete spec'd on Factory Build sheet
Black silicon vacuum hoses
Momo leather shift nob
Classic 80's in-dash K40 radar
Custom 9 speaker 3 amp stereo
Proudly owned since 1993.
3rd Place SPG SOC '11
1st Place SPG Tampa Saab Club '10
88SPG is offline
Old 10-23-2012, 01:31 PM   #11
yllwJet's Avatar
un named yellow swedish car (2000 Viggen)
ENGINE INTERNALS
block- line bored, decked, cylinders bored to 91mm
engine balancing
crankshaft straightened
wossner 91mm pistons
pauter 4340 chrome moly rods with arp bolts
calico coated bearings
modified t5 timing cover housing/oil pump
custom t5/t7 hybrid head. 3 angle valve job-t5 valves lapped w/ trollspeed 160# springs and enem 276/10.4 cams t7 lifters
modified adjustable cam gears
arp head studs
T7 multilayer headgasket
9.2:1 compression ratio
FUEL/RANDOM MODS
JZW custom tune
a/c delete
9-5 power steering pump w/ ss lines
maptun silicone radiator hoses
aeromotive 340 fuel pump
siemens 630cc injectors
ngk bcr8es copper plugs
B&M oil cooler w/ dual 4' spal fans
modified oil filter housing
royal purple hpr 15w40
TURBO SETUP
garrett gtx3071R w/ tial 0.63 A/R v-band exhaust housing
tial mvr 44mm external wastegate .8bar spring
tial mqr diverter valve
custom intercooler 24x12x3
custom 2.25 stainless steel intercooler plumbing
custom 3' aluminum cold air intake
GS modified turbo manifold and downpipe
GS 3' exhaust
SUSPENSION/STEERING/MOUNTING
18x7.5 BBS RK1 wheels BLACK PEARL
225/40/18 hankook ventus v12 tires
gs custom front coilover kit w/ koni race dampers and eibach springs
gs solid front upper strut mounts
gs rear race eibach springs
selholm racing control arms w/ heim joints
gs 22mm rear sway bar
gs race engine mounts
gs steering rack brace
gs rear axle poly bushings
gs poly steering rod bushings
gs rear hatch brace
BRAKES
stainless steel brake and clutch lines
front 308mm slotted/vented discs w/ hawk hps pads
rear 9-5 aero 300mm slotted/vented discs w/ hawk hps pads
super blue DOT4 brake fluid
DRIVETRAIN
gs solid race mount
gs short throw shifter
spec 3+ clutch
quaife lsd
saab 4.45 final drive
royal purple syncromax
ss clutch line
INTERIOR
JL AUDIO component speakers front
JL AUDIO 6x9 speakers rear
JL AUDIO 10' subwoofer and amp
Alpine headunit
innovate motorsports a/f gauge
aem boost gauge
aem fuel pressure gauge
aem oil pressure gauge
aem oil temp gauge
aem volt gauge
POWER OUTPUT
455whp 437ft/lbs
yllwJet is offline
Old 10-23-2012, 02:14 PM   #12
WSW
WSW's Avatar
^ You had my vote to begin with but that pic solidified it
99 Viggen
04 9-5 Aero Wagon
WSW is offline
Old 10-23-2012, 02:50 PM   #13
StoneSilver's Avatar
I think we all know who won this one
2000 9-3 SE - BCB Tuned
2008 Evo X GSR
Now the Car Gods @ DOT are gunna come Smack your PE PEE
StoneSilver is offline
Old 10-23-2012, 03:05 PM   #14
We_sleigh's Avatar
YellowJet, you were at h2oi right?
Old 10-23-2012, 03:44 PM   #15
upstateViggen's Avatar
I vote yllwJet for saab of the year
'99 Viggen
'05.5 Jetta
I'll be sticking around here for the MS paint wieners.
upstateViggen is offline
Old 10-23-2012, 04:08 PM   #16
yllwJet's Avatar
hahaha thanks for the compliments guys. wish i had something new to share about the car, but lots of big plans for the future
nope. not much of a car show guy
yllwJet is offline
Old 10-23-2012, 04:09 PM   #17
We_sleigh's Avatar
Hmmm there was a MCY viggen from NJ there. Had to ask lol!
Old 10-23-2012, 10:36 PM   #18
WSW
WSW's Avatar
So modest
99 Viggen
04 9-5 Aero Wagon
WSW is offline
Old 10-24-2012, 04:35 AM   #19
byastremski's Avatar
dammit pat i had my description all filled out waiting on a picture... then i refreshed the screen and saw yours there and decided fuck it... hahaha amazing car...
2001 Viggen BCB stg1
byastremski is offline
Old 10-24-2012, 05:41 AM   #20
yllwjet hasn't won a SOTM yet?
should have been given as a birthright or something.
BuHuSPG is offline
Tags
prentitious geeks, v6 cde ftw
