Submission For JULY'S SAAB OF THE MONTH - The Saab Link Forums
Go Back   The Saab Link Forums > Saab Of The Month > SOTM Submissions & Voting
SOTM Submissions & Voting Submit your car for voting & vote for your favorite Saab.
Old 07-18-2012, 06:45 AM   #1
Greek Mod
grkguy89's Avatar
We're off schedule again...
Ill try and get this back on track
The rules are posted in the sticky in the main section for SOTM Submission & Voting
(here's the link just in case; SOTM, Rules and other need to knows.)
Open for entrants!!!! Will close on the 24th
follow this template
***EXAMPLE***
The Silver Sled (1988 900 Aero)
Specifications
Engine
Brand new Saab B202 2.0 Litre 16 valve crate engine (installed November 2010)
Rebuilt Bosch distributor
Stock Bosch electronic ignition
SPG9 AID (Advance Ignition Diaphragm) with timing at 20˚BTDC
Bougnicord spark plug leads
NGK BCP7EV plugs
Aquamist 1S water Injection using 0.9mm injector
Aquamist DDD (digital dash display) for water injection output
Crank case ventilation catch-can
Exhaust
2.5 inch from cat converter back with hi-flow racing cat
4 inch chrome semi-oval tip
Hi-flow dynomax stainless steel muffler and rear resonator
3 inch JSP stainless steel split down pipe off turbo to cat
Turbo
Mitsubishi TE-05 16G: with 16G compressor wheel with 10˚ clipped vanes, upgraded thrust and is rated as a 300HP turbo
Wastegate running 7psi base boost
Stage 2.5 SPG9 APC running to 18psi boost
Jak Stoll Performance Talon high-flow side mount intercooler
8 inch Davies Craig thermo pull fan mounted on reverse side of intercooler with manual switch inside cabin
Saab C900 1990+ aluminium turbo intercooler ducts
Stratmosphere Forge bypass valve
K&N filtercharger
Plastic intercooler top air dam
Fuel System
Bosch 3.0 BAR fuel pressure regulator
Trionic 5 34lb injectors
Jak Stoll Performance Stage 2 ECU chip
Fuel pressure gauge situated in-line on fuel rail
Suspension
Stock Saab Aero springs and shocks
Stock Saab Aero road handling kit including front and rear sway bars
Polyair inflatable air bags inside rear springs
Wheels & Tyres
16" x 6.5" Saab Super Aero rims
Goodyear Revspec Ducaro 205/50/16 tyres
Other
Stock Saab Aero factory whaletail
Saab Aero vent covers (factory colour coded silver to match duco)
AutoMeter 30"hg to 30psi boost guage
AutoMeter air/fuel ratio guage
Saab factory rear decor panel
SaabSavior short shifter
Saab Momo leather steering wheel
3.5mm blue silicon vacuum hose
Saab Aero original Alpine surround sound 5 speaker stereo
Aero kit factory colour coded silver to match duco
Output
Estimated 190kW (250hp) at front wheels (need to do another dyno once new crate engine is run in)
1 PICTURE!!!!
Current Activity: Moderating
grkguy89 is offline
