2002 9-5 wagon won't start - The Saab Link Forums
Go Back   The Saab Link Forums > Welcome to The Saab Link > Saab News & Info
Saab News & Info Place topics regarding news and information for all Saabs in this forum.
Old 09-24-2019, 10:45 AM   #1
Angry 2002 9-5 wagon won't start
Battery OK, no codes posted. ignition on results in "check OK". twisting key to start position does nothing except flash "oil" and "check engine" lights. No code left. No sound of solenoid.
Happened about a month ago, car started OK after a few hours rest. Happened again yesterday and, again after a few hours, started OK.
Repair shop can find nothing wrong, suggests buying a new car!
but we love our wagon except for the failures to [email protected]!
Any suggestions?
nbyrne37 is offline
Old 09-30-2019, 10:17 AM   #2
Troup's Avatar
Send a message via AIM to Troup
Any suggestions?
This sounds like a failed crank position sensor. It's a very common on these Trionic 7 Saab's. I would start there. I've also had loose leads on the starter cause a similar issue.
I would suggest finding a more imaginative mechanic.
-1992 9000 T5
-1994 9000 Aero
-2004 9-5 Aero Wagon - Espresso Black
-2004 9-5 Aero Wagon - Glacier Blue
Troup is offline
Old 09-30-2019, 10:18 AM   #3
Troup's Avatar
https://www.esaabparts.com/saab/parts/55557326
-1992 9000 T5
-1994 9000 Aero
Troup is offline
Old 09-30-2019, 02:14 PM   #4
I'm reading this as: no crank/no start/no nothing.
If it's a stick shift, check bypass switch at clutch pedal.
Auto, try it in neutral when it acts up again (range switch).
Either case, check for corrosion/broken wires at the big plug under the hood at the firewall
seriks1 is offline
Old 10-02-2019, 08:00 PM   #5
Either a range switch (neutral safety) or starter assuming the battery is good.
Since you have no 'key not accepted' message I'll rule out immobilizer.
If you want to eliminate one or other and you are good at following directions....then get a test light. Identify the yellow lead going to the solenoid on the starter. Connect the grounding clip of the test light to a good metal surface on the engine....touch the probe end where that yellow wire is connected and have somebody turn the key. if it lights the neutral safety is good and power is getting to the solenoid. The starter is then in need of replacement...provided the large battery cable is good, connected and has battery voltage.
Saabjock is offline
Old 07-28-2020, 06:34 PM   #6
There are severals factors why your car won't start. Usually it is cause by a poor or dead battery which you need to replace immediate if you want to resolve the problem. You can charge it but you can only use it for a short period of time.
joynsuch is offline
Old 08-06-2020, 12:35 AM   #7
The ignition cassette is a common issue also.
troison is offline
Old 08-20-2020, 07:11 AM   #8
baldwin's Avatar
Yeah, especially for 2002 series. I like 9-5 wagons but the ignition cassette problem can create very big problems if you are preparing for a long trip. In 2010 we are going to Montenegro to complete some issues about my Montenegro citizenship and rented a 2002 9-5 wagon from the airport. On the way the car suddenly stopped working and it turns out the ignition cassette was toasted. I could barely catch my meetings...
baldwin is offline
