Gearbox oil question - The Saab Link Forums
Old 01-15-2015, 03:05 AM   #1
For the millionth time I know... but have to ask as there as so many opinions out there....
It is Jan 15, 2014... Have a 1997 Saab 900T manual trans with 150K miles. At the moment shifts ok. Last gearbox oil change was 55K ago.
I want to change the gearbox oil. To?
I keep reading about Redline MT-90. Or, what would you do here in 2015? tx
drhiii is offline
Old 01-15-2015, 04:31 AM   #2
Turbo00's Avatar
I always had the GM 0063 stuff in my viggen, worked great.
Turbo00 is offline
Old 01-15-2015, 07:09 AM   #3
Wagon Shaggin'
Saabeh's Avatar
Honestly, any good MTF will work. I am about to put Royal Purple synchromesh in my 9-5, but my fill plug is stripped
Saabeh is offline
Old 01-15-2015, 08:21 AM   #4
That sounds like a ton of fun, Mike.
Gonna weld a nut to it?
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 01-15-2015, 09:17 AM   #5
Wagon Shaggin'
Saabeh's Avatar
I think I could get a pipe wrench on the very edge, apart from that I'll have to be creative.
Saabeh is offline
Old 01-15-2015, 04:13 PM   #6
Excellent. Thank you for posting this reply about redline MT-90. I will probably run with that.
Another question, picking nits am sure. I have been studying redline MT-90 and there are two bottles... a red one and yellow one. They are labeled slightly differently. Something to do with sulphur, brass components, etc. There appears to be a difference.
Which bottle should I run with for a 1997 900T manual?
I know, going based on a color of a bottle is not exactly science, but may as well as it this way, or if there is an exact name for the redline MT-90, that would be cool.
tx
drhiii is offline
Old 01-16-2015, 12:35 AM   #7
Ok, last question on the matter. Have read a gobful of posts on gear box selections. Am about to go with Redline MT-90. Live in Colorado Springs, CO, where it is basically temperate, only getting real cold now and then. As the trany has 150K on it, figured to try a little thicker gearbox oil. Having said that... which would ya'lls go with:
Redline MT-90
or
Pennzoil Synchromesh Manual Transmission Fluid
Have read a lot of reviews and the latter seems to favor higher mileage trannys.
Thoughts?
drhiii is offline
Old 01-16-2015, 06:45 AM   #8
Wagon Shaggin'
Saabeh's Avatar
I was going to buy the Pennzoil or RP but I ended up with RP only because it was less expensive on Amazon, or something stupid like that. Both are fine.
Saabeh is offline
Old 01-16-2015, 10:36 AM   #9
The interwebs is full of myths and lore, but a recurring theme is that the Royal Purple stuff eats the bronze in modern transmissions, that, or it leaves Sulfur deposits on the bronze surfaces. A friend of mine put the RP synthetic stuff in his 528 and the shift quality became noticeably worse over time.
I'd go with the redline if you need to. Personally, I use the MTF0063 or Honda synthetic. Both are highly regarded as the best fluids out there. The redline makes a close third going by straw-pole.
Royal purple has an excellent marketing department IMHO. Going by BITOG, RP makes it's gains in HP by sacrificing lubricity. This equates to more wear and worse shear resistance.
_Cm
Cm452 is offline
Old 01-16-2015, 10:50 AM   #10
Wagon Shaggin'
Saabeh's Avatar
_Cm
Ehhhhhhhh, maybe. I have never seen an ad from RP. Does redline make anything that isnt 75w80 or 90? That stuff is much heavier than our 0063 or any othe MTF.
Saabeh is offline
Old 01-16-2015, 01:00 PM   #11
Drew in Houston's Avatar
I think you want Red Line 58304, it's their NS version, or the Saab 0063. You don't want friction modifiers, for sure in the later boxes, same I think for the earlier ones too.
Drew in Houston is offline
Old 01-19-2015, 11:37 PM   #12
I believe this is naming convention alone. That is to say 75w80 gear oil is about the same as 10w40 motor oil. I am not sure on the conversion, but several old timers have insisted it is the same thing. All I know is that the weight is not discrete, which would be the intelligent way to assay oils, but rather it is contextual; the same weights in different systems confer different nominal weights.
I only use MT0063 or the Honda stuff, as I previously said. This is because I am an easily confused creature and am subject to herd mentality, oh, that, and perhaps because I like the feel of those fluids, but I rely on the interwebs to make my mind up for me.
-Cm
Cm452 is offline
Old 01-20-2015, 05:27 AM   #13
srp
srp's Avatar
Send a message via AIM to srp
I think I used the MTL in my NG in the past and was unimpressed.
Did a full flush and switched to the 0063 and it made an improvement.
Next I am going to try the Pennzoil SYnchromesh.
srp is offline
Old 01-20-2015, 07:48 AM   #14
We just put delco syncromesh in mine.
I didn't realize that the pennzoil was so much less-expensive. I think I payed $16/qt of the GM, and Pennzoil was $9/qt when I looked online.
That being said, The trans had 30wt synthetic engine oil in it for the last 50k miles with zero problems, and a clean-ish magnet.
Craig R.
g96nt is offline
Old 09-15-2015, 01:52 AM   #15
hi I have a my car 93 aero 2005 my kilometer is 17778 km , I buy this car use and I don't know the history for gearbox oil changed ,
please advice me if I can changed our , how much kilo meter should I change the gear box oil ?
or I cant change at all .
daqqaq is offline
