FULL EXHAUST - The Saab Link Forums
Old 03-27-2004, 05:17 PM   #1
FULL EXHAUST
Can anybody please tell me where i can find a complete exhaust for my 96 900 turbo? Im talking 2 1/2 all the way , downpipe with a sport cat through the backbox. My factory downpipe is done and my car is loud as hell. I need the obnoxious noise gone. Please somebody post a reply!!!!
Phil is offline
Old 03-27-2004, 07:38 PM   #2
HNNLIC
Blaque's Avatar
www.GenuineSaab.com
Sport Exhaust system or JT Exhaust System (3")
I have the JT System (catless) on my 96 900 SET and it sounds nice...not loud but deeper than stock, also provides performance increases.
If you want a system WITH cat, its going to be more than one without.
Blaque is offline
Old 03-27-2004, 08:23 PM   #3
Now what happens when it comes time for you to pass emissions, you slipping the guy a 20 dollar bill or what?? This is why i want a cat.
Phil is offline
Old 03-27-2004, 08:31 PM   #4
HNNLIC
Blaque's Avatar
Well here in the midwest, we don't have emission checks. So I can get away with not having it.
In your case what most people do is purchase the catless exhaust system from Genuine Saab and buy the cat from another company (you can find a cat online for about $40). Then when you have the system installed, just have them add the cat as well. Tends to save money, and you can pass emissions.
Blaque is offline
Old 03-27-2004, 09:00 PM   #5
Ill definetely take that in to consideration. Thanks a lot, you've already been a lot of help!
Phil is offline
Old 03-27-2004, 10:53 PM   #6
HNNLIC
Blaque's Avatar
No problem
Blaque is offline
Old 03-28-2004, 10:57 AM   #7
JABM's Avatar
Send a message via AIM to JABM
Saabsavior also makes a full turbo to tailpipe 2.5" stainless exhaust for our cars, with cat.
JABM is offline
Old 03-28-2004, 11:16 AM   #8
whats the link to saabsavior?
Phil is offline
Old 03-28-2004, 12:26 PM   #9
www.saabsavior.com
I've got his 2.5" cat-back - very nice and throaty, really woke up my turbo, too
Q-SAAB is offline
Old 03-28-2004, 12:34 PM   #10
ill keep this in mind as well. Thanks !
Phil is offline
Old 03-29-2004, 01:36 AM   #11
Administrator
bollman's Avatar
Send a message via ICQ to bollman Send a message via AIM to bollman
Even though it doesn´t apply to this car, remeber that if you have a 9-3 with LPT 154hp, the car won´t run at peak performance if you remove the cat. If the second lamda is too high, the Trionic thinks the cat is broken and therefore puts the program in "limp-home" mode, which means looow power
bollman is offline
Old 03-29-2004, 11:16 AM   #12
b dash rian's Avatar
and saab savior doesnt have an exhaust for the ng does it??
b dash rian is offline
Old 03-31-2004, 12:25 AM   #13
JABM's Avatar
the do have one for the NG, it's not on the site but I emailed.
turbo to tailpipe, with cat, 2.5" all stainless, I think he quoted me at $1050, but I can't remember for sure
JABM is offline
Old 03-31-2004, 08:20 AM   #14
I would also ask Jeff at http://scanwestauto.com/ or Bo at www.Engstrom.net
They will be able to get you a SS system for cheaper than anyone else, at lest when i was looking that was the case. Probably around $1000 turbo to tail pipe
CO-Saab is offline
Old 03-31-2004, 08:33 AM   #15
HNNLIC
Blaque's Avatar
Group 9 Performance has a SS system as well, also one for the Viggen for around $1000.
Blaque is offline
Old 03-31-2004, 02:10 PM   #16
I just purchased the 3" JT system from taliaferro, with a cat, turbo to back box for $850.
Phil is offline
Old 04-01-2004, 11:12 AM   #17
Administrator
bollman's Avatar
Info: When you install a 3", you´ll probably need to modify the WG! Test the installtion with disconnectiong the magnetic valve and run a few strips with a good turbo gauge. You´ll see that the pressure rises on high rpms. That needs to addressed, otherwise you can get dangerous knocks, since the ECU can´t compensate enough. My pressure rose from standard 0.4bar to 0.6 which is way too high. I´ll need to modify the WG before going stage 3. Those of you with a B204R (9-3 200hp T5, not the 205 T7) already have this modification and should not see this rise in pressure.
bollman is offline
Old 04-01-2004, 04:08 PM   #18
Now first, when you write "WG" you mean wastegate correct? Second, do i need an uprated ecu to run a 3' exhaust?/?
Phil is offline
Old 04-01-2004, 09:15 PM   #19
Administrator
bollman's Avatar
Yes WG=wastegate and no, you don´t need to upgrade the ECU. The standard one will adopt to the new enviroment. But, check that the pressure goes haywire, but remeber to disconnect the magnetic valve to test. Testing with full pressure shows nothing.
bollman is offline
Old 04-02-2004, 04:04 AM   #20
So what kind of afternarket wastegate can i get for my 96 saab turbo?? It's been very rare that I've seen a saab with an aftermarket wastegate. So if you could help me out I'd appreciate it. I dont want to destroy my saab.
Phil is offline
