correct braided coolant AN line size? - The Saab Link Forums
Old 08-25-2014, 11:10 AM   #1
Hello so I bought this off eBay Turbo Water Coolant Line Kit M12x1 5 mm Volvo Saab TD04 | eBay the other day and am waiting for it arrive. The reason I want this is cause I have leaky line on the turbo side with oversized washers. And want to fix it with a braided line. I didn't really notice till after I bought it that it said the hose size is 4an. I somewhere thought I read on here about someone making there own and used 6an hose. Now my questions are will 4an be to restrictive? Or will it be okay? I just to know that the turbo is getting all the coolant it needs.
Thank you Connor
condaddy is offline
Old 08-25-2014, 11:31 AM   #2
B202nut-2.0's Avatar
a generic answer regardless of car:
Seems you will only increase whatever the initial pressure in the line was (2mm difference in diameter or whatever unit used to measure size inches/mm).
Doubt your gunna starve anything, coolant should still get where its going, if this is for your turbo, its only to cool things down. the galley area around turbos moving parts that needs to be cooled isnt compromised so you should be just fine.....
just a thought...
B202nut-2.0 is offline
Old 08-25-2014, 04:31 PM   #3
just a thought...
Ok thank you for your input. I'm going to compare diameter of it with a old coolant line I have cut in half. I will let you guys know. Also if anyone who reacts this and has braided lines on there turbo please share weather it's 4an or 6an.
Thank you Connor
condaddy is offline
Old 08-25-2014, 04:49 PM   #4
DrewP's Avatar
For AN style hoses and fittings the "dash" number (-4 or -6AN in your case, you pronounce that as a "dash four" or "dash six" hose / fitting) is the inner diameter of the hose or fitting in 1/16ths of an inch, so a -4AN is 4/16ths = 1/4" inch inside diameter. That's much larger than the OEM coolant lines to the turbo already, they are only about 1/4" in OUTSIDE diameter. The flow thru the turbo will be limited by the banjo fitting feeding it anyway, it's cross sectional area that can flow is MUCH smaller than a 1/4" inch circle.
That convention is true of any fluid system conforming to AN (an old Army Navy standard, where the name "AN" comes from).
You'll be fine.
DrewP is offline
Old 08-25-2014, 05:59 PM   #5
You'll be fine.
Thank you that is what I wanted to hear! I appreciate your input and time!
condaddy is offline
Old 08-25-2014, 08:32 PM   #6
DrewP's Avatar
Happy to help with info that's actually useful!
DrewP is offline
