Two cars, Three engines - The Saab Link Forums
Old 07-30-2014, 04:58 PM   #1
chevyman's Avatar
Its been a while since I've posted anything really productive, or done anything really productive, but I believe that's about to change. My buddy, Jordan, drives a 2001 9-3 SE. Unfortunately it has begun to knock, and needs a motor sooner than later.
I've got a 95 900. 2 door, 2.0 turbo, Some of you may have seen it on here before. It runs like a champ, but I've had a 2.3 sitting around for a couple years. So we've come up with a little scheme that should solve all our problems.
Jordan's buying my motor, and will make a 204/205 hybrid. It has the td04 and crossflow already, and we will be adding the t5 cams, 3" downpipe and an intake.
My car has a td04, Forge WGA, crossflow, 2.5' downpipe, t7 bpc and a t5suite stg2 tune installed currently. The 2.3 is from a 1998 9k. I have the 6cm td04 from the car as well as a viggen clutch to install. I will also do a hydraulic clutch conversion while I'm in there.
In addition, both cars will be getting tunes from MikeD!
This should all get started in a week and a half or so, I just placed orders at Rock Auto, Eeuro, GS, and Amazon, so hopefully we will have everything we need when we get started!
Ill throw in some pics of the cars to start, hopefully there will be plenty more as the project progresses.
IMAG0624 by awill141, on Flickr
IMAG0623 by awill141, on Flickr
IMG_20140730_200450948_HDR by awill141, on Flickr
1995 900 se turbo
chevyman is offline
Old 08-02-2014, 12:38 PM   #2
chevyman's Avatar
The parts are starting to arrive! Just a few boxes so far, a few more to come. I ordered some parts to make myself a decent intake as well.
If all goes as planned we should be getting started next Saturday!
Pic of the 2.3 donor. I might have a valve cover with 2.3 written on it to install, but I'm not too worried about that.
76127_10150108983864951_1309736_n by awill141, on Flickr
1995 900 se turbo
chevyman is offline
Old 08-07-2014, 09:17 AM   #3
chevy4life's Avatar
Parts at the machine shop will be finished this afternoon!
chevy4life is offline
Old 08-08-2014, 10:21 AM   #4
chevyman's Avatar
All the parts are here. We should be getting started bright and early tomorrow morning.
My stuff:
IMAG0683 by awill141, on Flickr
IMAG0685 by awill141, on Flickr
Jordans stuff:
IMAG0682 by awill141, on Flickr
IMAG0684 by awill141, on Flickr
1995 900 se turbo
chevyman is offline
Old 08-08-2014, 01:07 PM   #5
So what machine work is happening? Rebuilds all around?
Tboy is offline
Old 08-08-2014, 01:26 PM   #6
chevyman's Avatar
No rebuilds unfortunately. The b234 going into my car is a good motor and so I will just be putting that in as-is. I had the flywheel shaved because I am upgrading to a viggen clutch. I have another b234 that I will do a full rebuild on in the future if I decide to run a holset.
We had the t7 head checked and shaved to go onto the b204 bottom end, which also shouldn't need any work. So that motor will have a fresh head gasket.
We are both replacing lots of seals etc and some other wear items as well.
1995 900 se turbo
chevyman is offline
Old 08-09-2014, 03:16 PM   #7
chevyman's Avatar
Garage cleaned up and ready to go!
IMAG0686 by awill141, on Flickr
My car pulled in. Almost time to go under the knife.
IMAG0687 by awill141, on Flickr
Cleaned up the b234 a bit. Still needs my ng900 oil pan and timing cover installed, then some more cleaning and a little paint.
IMAG0691 by awill141, on Flickr
IMAG0690 by awill141, on Flickr
A couple hours later and my motor is out and Jordans car is pushed in.
IMAG0694 by awill141, on Flickr
IMAG0696 by awill141, on Flickr
1995 900 se turbo
chevyman is offline
Old 08-10-2014, 12:33 AM   #8
bogan's Avatar
looks good..
I wish I had a garage like that
bogan is offline
Old 08-10-2014, 06:06 AM   #9
chevyman's Avatar
Thanks bogan. I'm a bit spoiled from the garage, it is really nice.
We made some more progress yesterday. The b204 is stripped down to the short block. At that point we pulled Jordan's b205 out and stripped it as well.
Hopefully today we will have the 204/205 hybrid together and running in Jordan's car.
B204
IMAG0698 by awill141, on Flickr
B205
IMAG0697 by awill141, on Flickr
View from below
IMAG0699 by awill141, on Flickr
Jordan trying to take the turbine nut off with the impact, (Just Kidding)
IMAG0695 by awill141, on Flickr
Jordan's car up on the lift, waiting for its new engine
IMAG0703 by awill141, on Flickr
And we have just a few parts scattered around
IMAG0700 by awill141, on Flickr
IMAG0701 by awill141, on Flickr
IMAG0702 by awill141, on Flickr
1995 900 se turbo
chevyman is offline
Old 08-10-2014, 11:08 AM   #10
I love using the lift for engine swaps. Pulled a motor out of a saturn yesterday.
I also have a civic eg (1992-1995) and that has no subframe!! Motor swaps are even easier!!
Tboy is offline
Old 08-10-2014, 11:11 AM   #11
One thing I have done for my garage is build a few subframe carts. Find some inexpensive casters and they make jobs simple.
Here is one I made for the ng900. It has the v6 I am swapping out on it.
Tboy is offline
Old 08-10-2014, 05:46 PM   #12
chevyman's Avatar
I like the subframe cart idea! I may have to do something like that someday.
Well, we are picking up another 9-3 tomorrow to receive the 204/205 hybrid, and the silver car will be parted out. Rust and lots of bodywork are the culprit. More details and some pictures will come
1995 900 se turbo
chevyman is offline
Old 08-11-2014, 04:31 AM   #13
chevyman's Avatar
We took a break last night to go visit Jordan's parent's kitten!
IMAG0704 by awill141, on Flickr
IMAG0705 by awill141, on Flickr
IMAG0706 by awill141, on Flickr
1995 900 se turbo
chevyman is offline
Old 08-11-2014, 06:03 PM   #14
Will the cat be helping with the build? Carrying small parts for you perhaps?
BobSabbert is offline
Old 08-13-2014, 07:29 AM   #15
chevyman's Avatar
No , but that would be great!
So Monday morning we went and picked up the new car. A black 2001 9-3 SE. It is in much better shape than the silver car. We had the engine out Monday night.
IMAG0716 by awill141, on Flickr
IMAG0715 by awill141, on Flickr
IMAG0713 by awill141, on Flickr
By that time we had a whole garage bay filled with parts
IMAG0714 by awill141, on Flickr
Tuesday we began to install the 204/205 hybrid, and had that done and driving at about 2:30 in the morning.
IMAG0726 by awill141, on Flickr
IMAG0727 by awill141, on Flickr
IMAG0725 by awill141, on Flickr
1995 900 se turbo
chevyman is offline
Old 08-13-2014, 09:33 AM   #16
B202nut-2.0's Avatar
Love the stance on that VW??
Sleeper!!!!!!!!!
B202nut-2.0 is offline
Old 08-13-2014, 11:36 PM   #17
chevy4life's Avatar
That corrado has a mk3 TDI swapped into it. Not a sleeper to say the least but it gets about 50+ mpg, and its original to say the least.
Old 08-15-2014, 06:40 AM   #18
Oh! That's too funny! Great idea!!! Love the engine, love the car. Would NEVER have thought of putting the two together.
win_k is offline
