koni or bilsteins - The Saab Link Forums
View Poll Results: koni or bilsteins?
koni 10 71.43%
bilsteins 4 28.57%
Voters: 14. You may not vote on this poll
Old 04-24-2014, 10:32 AM   #1
Greek Mod
grkguy89's Avatar
koni or bilsteins
whats better for really low stiff suspension up front?
Current Activity: Moderating
grkguy89 is offline
Old 04-24-2014, 11:15 AM   #2
I don't know.
Old 04-24-2014, 12:10 PM   #3
Greek Mod
grkguy89's Avatar
i know where i stand, but i want to make a sticky for others
i keep getting PM's with the same question
i tell people it's a matter of preference
so why not see what most have or prefer
grkguy89 is offline
Old 04-24-2014, 12:12 PM   #4
gm
gm's Avatar
Most haven't owned both and prefer what they own or purchased
I am on the koni side.... Been using their stuff for many years in my SPG as well as in my viggen with aftermarket springs. Great stuff..... Rode in a few bilsteins equipped c900's but never a newer saab thus no comment
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 04-24-2014, 12:15 PM   #5
I have had both and my vote is with Koni yellow adjustables.
My first set was killed by a set of Intrax. Koni not only rebuilt them for free, but custom valved them to match the set of Eibachs I was going to use for no cost to me. Customer service FTW.
Jameson is offline
Old 04-24-2014, 12:45 PM   #6
Koni's are adjustable for rebound. Bilsteins offer their benefits on the compression side. Both are good. I personally like the 'steins better. They are much cheaper, and much more substantial. Plus, they are aggressively valved for lowered cars. I have ridden in cars equipped with both; the Koni's on full soft are softer than the billy's, but that is about it. I really don't like the way the car feels with Koni's--to me, it feels like air suspension that has been pumped to "full hard", like you are riding around on over inflated dodge-balls. Other people say the billy's are made of granite--I respectfully disagree. The main problem is actually endemic to both makes; our suspension is so limited in terms of travel on a stock setup, that lowering it gives you ~1.5" before the bump-stops. This makes for a miserable experience when you slam a bump and it all goes into your strut towers with a calamitous "BANNNG". Lastly, my gripe with the Billy's is that they have this trick valving that makes them go soft upon impact with a howler, which exacerbates the aforementioned problem.
YMMV.
The question is whether or not you can be lead to believe the Koni's are worth the price difference.
-Cm
Cm452 is offline
Old 04-24-2014, 05:59 PM   #7
NickTurbo900's Avatar
Driven/owned both on OG 9-3s.
Konis ride better on a less than perfect pavement. Less busy, less jarring.
Both are impressive on pefect pavement.
I have Bilsteins on my Driver SPG, it rides well and I like them. I did not like the Bilsteins on the 9-3. I have a full set of Konis to try on my other SPG (too nice to DD) this summer.
NickTurbo900 is offline
Old 04-26-2014, 05:38 AM   #8
Yeah, I need to install my bilsteins in the viggen to really have an apples to apples idea.
Old 05-14-2014, 11:58 AM   #9
93viggen's Avatar
I had Koni "reds" on my track oriented SPG. They were terrible with whatever spring rates I was running. Went with the bilsteins and I could brake later and come into corners harder and faster. I liked them on the c900 way more than the Konis I had. Had both brands on my og9-3's too. I like the koni race and koni sports better than the bilsteins on that car. For a lot of reasons....
Sent from AutoGuide.com Free App
Using waste to make haste!
93viggen is offline
Old 05-14-2014, 04:27 PM   #10
PAviggen's Avatar
I've owned both, the adjust-ability of the konis is extremely useful. with that said when tuned full stiff the bilsteins are firmer and i actually prefer them
even stiffer is when GS turned my konis into coilovers (obviously) - if you ever plan on doing this the konis are the better investment
PAviggen is offline
Old 05-15-2014, 04:30 PM   #11
YMMV, but everyone I know who did a suspension swap with Eibach pro's and Koni yellows, blew them. Also, I drive on 16's, and find the Bilstein comfortable. The OP also stated low and stiff, in which case, the Koni's are not a good move. Reports come in from many places that they blow out when aggressively lowered. Lastly, speaking purely as conjecture, I believe the bump-stops in the Bilsteins are bigger, and thus, you are more apt to hit them when you hit a howler of a pot hole. This would make the ride seem firmer for sure. To put things in perspective on how "hard" the Steins are; my dad has a 06 9-5 ARC (the midgrade one) and I cannot compress his suspension by shoving down on the front fenders, whereas my car, equipped with the mean and nasty Steins can be.
-Cm
Cm452 is offline
Old 05-19-2014, 07:49 PM   #12
gm
gm's Avatar
I have the koni kit on my viggen for over 60k miles and zero issues
On the old spg's I used koni's on two cars with intrax and one with brad at kc saab's adjustable springs, I think I did 550/750# springs..... Intrax I loved until I tried brads springs.... Never had a single issue with the konis with either setup, matter of the springs being to low of a spring rate with intrax. Had excellent luck with the stiffer adjustable spring and koni.... Attended maybe a dozen track days with the adjustable springs and koni's, only a handful with intrax/koni. Best improvement I had in stopping power was the ap racing brakes
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 05-19-2014, 10:18 PM   #13
DEW
I chose Bilstein shocks because I have previous positive experience with them on older Saabs. Considered Koni, but I wasn't interested in adjustability, and they were more expensive (at the the time).
DEW is offline
