LinkBack | Thread Tools |
#1 |
Intake Manifold fitment..
Would it be possible to fit the B234R intake manifold to a B204L? The heads are the same, no?
Reason being, will I gain any performance points doing this mod? (hx40 build on the way). Port matching and polish along with a bigger TB
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Sponsored Links | |||
#2 |
Anything is possible.
#3 |
Plumbing wont be a problem as i'm looking for the overall performance benefit of having a plenum type manifold than the top fed manifold the b204l has (although members are making some high hp numbers using the stock manifold)
#4 | ||
People spoke about the 2.3 NA mani adding some torque.
#5 |
im not sure i would use the Na manifold from a 2.3 NA ng900, or an NA 9000 the ng900 manifold tends to overcharge the middle two cylinders under boost, on this can cause a lean symptom on the middle two, resulting in melted parts
the NA 9000 manifold i always debate on, it does make power, and torque. But it also makes servicing the car a horrible experience. the NA 9000 manifold drasticly lowers intake temps, a large amount of the gain comes from this. and the gains are less significant with a big intercooler. i like the b204 central intake the best. Mike d
MikeDTuning.com |
#6 |
i have a nice NA9000 manifold setup available for very cheap.
Current: 1999 LB 9-3 Viggen, 2002 SG 9-3 Viggen Vert, 2003 Cosmic 9-5 Aero To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Sponsored Links | |
Thread Tools | |
