Bov help - The Saab Link Forums
Old 12-21-2013, 01:34 PM   #1
Bov help
Long story short my stock bpv was making an annoying hooting noise . I had a knock off greddy Bov sitting in the garage and welded the flange on the stock ic pipe. Now I seem to get nothing but flutter . Bov doesnt move any air. Is there another way I should be running the vacuum line.?
ridin59vette is offline
Old 12-21-2013, 01:36 PM   #2
Installed Pic
[/URL]
Old 12-23-2013, 04:26 AM   #3
Maybe it's the knock off bov.
Old 12-23-2013, 09:45 AM   #4
Greek Mod
grkguy89's Avatar
Top screw looks like it's way too tight (too much preload on the piston)
Try backing that off a good amount
If that doesn't work then you may need a brand name valve
Current Activity: Moderating
grkguy89 is offline
Old 12-23-2013, 01:00 PM   #5
Thanks Guys. I messed with the Valve a bit but it made no difference in or out. I'll swap it out and see if it makes a difference
Old 12-23-2013, 01:01 PM   #6
Could be. I know plenty of locals running them on High hp hondas builds with no issues. I wouldn't run it on my 600Whp Srt but on a car I paid 400$ for who cares.
Old 12-23-2013, 02:58 PM   #7
DrewP's Avatar
The vacuum line needs to be on the manifold side of the throttle body. If you have it connected to one of the nipples upstream of the throttle plate it will do that.
DrewP is offline
Old 12-23-2013, 03:19 PM   #8
I haave it connected to the stock line for the factory bpv, Should I be using a different Source?
Old 12-23-2013, 03:26 PM   #9
DrewP's Avatar
If your stock line was in the wrong place you would.
DrewP is offline
Old 12-23-2013, 03:27 PM   #10
ITs connected to the front of the tb. Ill post a pic in a minute
Old 12-23-2013, 03:30 PM   #11
Line on the right. Directly under the coolant hose
Sent from AutoGuide.com Free App
Old 12-23-2013, 04:16 PM   #12
Nevermind, According to this diagram i found all lines are run exactly where they are supposed to be. On a side note the adjustment screw had alot more soft adjustment then I had thought previously. I'll update tomorrow since i've had a few to many beers to give it a loop around the block
http://www.saabwiki.info/images/2/28/Vh_1a.jpg
Old 01-13-2014, 02:14 PM   #13
To update the thread. Once I had some time and after a good amount of research I found that The Bov was fine, I had to remove the helper spring from the Bov. There was to much pressure. Now it functions perfectly
Old 01-13-2014, 04:23 PM   #14
Drew in Houston's Avatar
Glad you figured it out! It's nice that you followed up, too many people come here, ask for help, and then there's never any followup for someone who may be searching in the future.
Drew in Houston is offline
Old 01-13-2014, 04:49 PM   #15
No problem man. I hate finding a thread with the issue I'm having and no resolution
Old 01-15-2014, 09:13 PM   #16
I would also like to ad for future reference, that while off-WOT performance will suffer slightly, you can run a piston-type recirc-made-BOV with NO SPRING. YES, NO SPRING. This is because it works off pressure differential, and not the actual pressure of the spring to seal. In fact, too tight is bad, because part of the reason for a BOV/Recirc is the pop open on blips to preserve throttle response, otherwise, you have to accelerate all the air in the circuitous intake manfild, starting from the turbo, then the intercooler, etc. This can make the engine gulp and then sputter.
All in all, it should pop if you blip the gas from idle. Anything more is too much.
-Cm
Cm452 is offline
