Homemade BOV - The Saab Link Forums
Old 12-15-2013, 10:49 AM   #1
Homemade BOV
Ive been doing some looking, and peolpe where making homemade BOVs.
I know that you are supposed to take off this pipe shown in the picture and block it off.
Then this is where I am confused, In this picture they say that I am supposed to put some filter on it or something like that?
Sorry for such limited information on this.. All the threads that I have found containing this information have been incomplete.
zercs7 is offline
Old 12-15-2013, 11:00 AM   #2
Wagon Shaggin'
Saabeh's Avatar
Basically, you remove that rubber hose and somehow block the port on the intake. You should run a filter on the BOV because it will suck in unfiltered air under vacuum.
Saabeh is offline
Old 12-15-2013, 05:49 PM   #3
Alright so I have the pipe removed. Is there anyway to make it a bit louder?
zercs7 is offline
Old 12-15-2013, 06:35 PM   #4
Moreboost's Avatar
Get a BOV
Moreboost is offline
Old 12-15-2013, 06:46 PM   #5
Yup. You have two ways of making it louder: run more boost, thus making the purge of excess boost louder; or get a BOV that's slightly restrictive and forces the expelled boost through holes or horns to magnify the sound.
Old 12-15-2013, 08:13 PM   #6
mike d's Avatar
you really should keep it recirculated if you are not going to use a filter, a cool noise isn't worth getting stuff sucked into your motor
MikeDTuning.com
mike d is offline
Old 12-16-2013, 05:25 PM   #7
I was getting told that there is alot of speculation as to where this actually sucks any air in. From what I felt it only blows air out. So I should recirculate it just to be safe before I get a BOV?
zercs7 is offline
Old 12-16-2013, 05:54 PM   #8
Get a small bit of foam or panty hose and zip tie it it on.
Old 12-28-2013, 08:57 AM   #9
Saab95Aero's Avatar
Get a forged BOV, the stock plastic one sucks and leaks also an open air intake will make it nice and loud. use a plastic bottle cap to cap it lol its ghetto but it works
Saab95Aero is offline
Old 12-28-2013, 03:22 PM   #10
Doesn't really. Eventually it melts or becomes so thermally fatigued that it cracks and disintegrates. Ask me how I know... instead, go to a hardware store and get a threaded steel end-cap, IIRC, 1" ID. This literally threads onto the exposed port on the intake.
They don't really suck in that much air. The likelihood of doing damage from the minute amount of particulate taken in is nil. Most of the time, even during engine vacuum, they are closed or venting positive pressure. The only time they fringe on sucking in air is during throttle blips.
-Cm
Cm452 is offline
