Viggen t5/b234 BUILD! Made a decision! - The Saab Link Forums
Old 11-01-2013, 01:16 AM   #1
93viggen's Avatar
I have come to the decision to build a b234 for my Viggen that I just picked up for cheap due to having a blown motor. I have been wanting to do all this for a long time now, and I have the opportunity right now, so I could not justify not doing it .
I ordered all the parts needed for a rebuild and a lot more tonight!
Parts list for build:
B234 block (t5), t5 cylinder head, 234 timing cover and oil pump.
235 oil pickup tube, b235 oil pan, b235 wind-age tray.
T5 intake manifold injector flange (to retain proper injector angle). T7 runners and plenum to retain t7 components such as throttle body, MAP sensor location, etc.
Pauter connecting rods (147mm)!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Wossner pistons.
Main and rod bearings (standard Glyco, miced the crankshaft and checked oil clearances which allowed me to buy all my parts now ).
Thrust washers/bearings.
All seals, gaskets, o-rings, valve stem seals, etc. (All OE).
Permatex/Loctite 518 anerobic sealer.
Power steering high pressure hose. P/s return line from rack to reservoir.
Genuine Saab t5 uprated valve springs.
Genuine Saab balance shafts delete kit.
ARP head stud kit.
ARP main stud kit (pending along with the Spec stage 3+ from John). OE slave cylinder kit.
ARP flywheel bolts.
AEM 320lph in tank fuel pump.
Axle/differential seals.
Selector shaft seal and bushing.
Accessory drive belt, retaining air conditioning.
Heater hose kit.
Upper and lower radiator hoses.
Coolant pump hose.
HEPU coolant pump kit.
82 degrees Celsius thermostat kit.
Exhaust manifold stud kit.
Silicone vacuum line (12 feet).
Master timing kit (guides, chains, tensioners, oil pump o-ring, valve cover gasket, oil cooler o-rings, etc. Available through Eeuroparts for $200~ which is a steal).
NGK BCPR7ES spark plugs.
Autometer oil pressure, Prosport EGT, and boost gauges.
Genuine Saab top mount exhaust manifold. (bought used).
Genuine Saab top mount down pipe, with 3" v-band option. (bought used).
Garret GT3071r turbocharger.
Forge bypass valve.
MP performance intercooler (used).
875cc 80lb/hr Siemens injectors with fuel rail spacers.
BSR cold air intake.
All turbo hardware, plumbing, coolant, oil lines, etc.
Genuine Saab stock location turbo bypass valve plug (used).
New t7 ignition discharge module.
That is all I can recall at the moment. Just saw my bank account skyrocket down!
Should be seeing about 50 boxes of parts in the next month~.
Then as soon as it all arrives I am headed to the machine shop!
These guys are local to me I just found out, talking to them about machine work and pricing! Maybe I can get us some hookups .
This thread will be picture heavy, I document every step of everything I do on my cars.
Using waste to make haste!
93viggen is offline
Old 11-01-2013, 06:41 AM   #2
Holy good god. There seem to be some serious builds going on these days!!!
BuHuSPG is offline
Old 11-01-2013, 07:37 AM   #3
93viggen's Avatar
It is going to be serious! Trying to get it done in 2~ months!
I am gonna be posting detailed pictures of the swap along with all the parts I receive.
93viggen is offline
Old 11-01-2013, 08:59 AM   #4
WSW
WSW's Avatar
Jealous. Should be nasty when it's done
99 Viggen
04 9-5 Aero Wagon
WSW is offline
Old 11-01-2013, 06:26 PM   #5
Area6's Avatar
Similar to wats going on with my 9k.. goodluck
Area6 is offline
Old 11-04-2013, 05:25 PM   #6
93viggen's Avatar
Pauter connecting rods and some other various parts I ordered arrived today!!
Pictures of the Pauter rods dimensions, weights, etc. And, Pauter rods next to T5 rods. For the purpose of comparison.
93viggen is offline
Old 11-04-2013, 08:07 PM   #7
turbojohnny's Avatar
This should be good
turbojohnny is offline
Old 11-05-2013, 05:39 PM   #8
93viggen's Avatar
Originally Posted by turbojohnny View Post
This should be good
I promise, it will be! Just a few months! Looking for a reputable machine shop somewhat near me at the moment.
More stuff ordered:
ARP Ultra torque lube.
VHT ceramic high temp paint.
VHT black pearl engine paint (for my Engine block).
Redline MTL.
Redline assembly lube.
Comp Cams spray lube (always helps my assembly lube stick to the camshafts, lifters and the rest of the valve train better).
Vasoline (for priming the oil pump gears).
93viggen is offline
Old 11-06-2013, 10:01 PM   #9
StoneSilver's Avatar
Why not go with Maptun Hoses?
2000 9-3 SE - BCB Tuned
2008 Evo X GSR
Now the Car Gods @ DOT are gunna come Smack your PE PEE
StoneSilver is offline
Old 11-06-2013, 10:48 PM   #10
93viggen's Avatar
I had an entire set of DO88se hoses on my black Viggen... I cannot justify spending three hundred or more dollars on coolant hoses when I got all these for under forty bucks...
I think that you want me to buy them since I am probably selling the car shortly after finishing it hahaha.
93viggen is offline
Old 11-07-2013, 07:20 PM   #11
93viggen's Avatar
Update! Got my coolant pump, AEM 320LPH fuel pump, ARP flywheel bolts, high pressure power steering line and slave cylinder in today! As well as another coolant hose and selector shaft bushing and seal.
93viggen is offline
Old 11-08-2013, 05:05 PM   #12
bogan's Avatar
Looks good .. I'll be watching this
bogan is offline
Old 11-08-2013, 05:47 PM   #13
Do you have a Quaife in that car? Really looking forward to this build, post many pictures if possible.
Whilhelm is offline
Old 11-09-2013, 09:32 AM   #14
93viggen's Avatar
According to the previous owner, yes, it does have a Qauife LSD. He even showed me receipts of Pearce European AND Japanese doing the work! I know they specialize and are very passionate about SPG's. But I will know for sure when I get it all out of the car and apart!
I will be taking many, many pictures. I am documenting the entire build, for learning purposes and just to have in case anything goes wrong in the future I can see what I did and did not do... And, of course to show people .
93viggen is offline
Old 11-09-2013, 10:28 AM   #15
WSW
WSW's Avatar
Sweet. I wouldn't mind building the motor in my Vig sometime soon so pics/DIY/tutorials would be great
99 Viggen
04 9-5 Aero Wagon
WSW is offline
Old 11-10-2013, 07:32 PM   #16
93viggen's Avatar
I am documenting the entire process!
I got the engine and transmission assembly out today. It was a HACK job to say the least. Someone put a b235e in this car... It is missing bolts, has the wrong bolts, everything is either loose or way over torqued, it was missing a c-clip on one of the axles... Just a total nightmare, no wonder it blew up!
I got the transmission and engine separated. got all the engine accessories, brackets and whatnot off and apart. I got to start cleaning, too!
Here are some pictures!
Yes, I do have a lift in my backyard... Lol.
And the carnage! Hole through the engine block! Well, more like an oval, also a gash through the oil pan, anyone need part of a piston?!
My pops showed me something I did not know today, too. Apparently the idler pulleys and tensioner pulley bearings are re-greasable. I took them apart, cleaned them very well and greased them with Maxima water proof grease, have used it for years on my motorcycles with great results!
Some clean parts!
93viggen is offline
Old 11-14-2013, 06:16 PM   #17
93viggen's Avatar
*Update* for anyone that cares or is interested. Got some boring parts today! But, I also ordered my clutch and Pistons as well last night, after having the cylinder bores pressure checked and after measuring them I have decided to remain at the stock bore. The taper was max of .0003" and was only worn .0006" over stock bore. That is fine due to Wossner recommended a slightly enlarged bore for what purposes I am building the engine for . It will be honed to the correct RA when they arrive, then everything is getting weight matched, balanced and a final check.
Some parts that arrived today! Axle boot kits. Crankshaft position sensor as my other got destroyed from the trigger wheel bending and annihilating it. Oil pressure switch. Lower expansion tank hose. Injector o-rings and throttle body upper o-ring. Exhaust hangers. And a Viggen intermediate shaft and bracket. Do not ask why -___-.
93viggen is offline
Old 11-19-2013, 10:45 PM   #18
93viggen's Avatar
*Another update*
Tonight I was able to clean my filthy engine bay as well as my subframe. When the engine let go all of its oil went all over the place. I got to use my new pressure washer and it was well worth the investment!
Got my new control arms in, stanchion arm bushings (not too fun to press in and out), tie rod ends, sway bar links and sway bar bushings.
Here are some pictures of old compared to new. I also polished up the stanchion arms before I fit the new bushings in.
Wossner slugs should be here in one month~, clutch is on its way as well as my ARP main studs!
93viggen is offline
Old 11-20-2013, 09:22 AM   #19
awsome thread I wish I could afford to do this to my car! but will def be watching this one, good luck!
condaddy is offline
Old 11-20-2013, 09:16 PM   #20
One month wait for the Pistons? thats crazy
2008 Evo X GSR
