high positive Amul, seeking remedy - The Saab Link Forums
Old 09-03-2013, 09:33 PM   #1
It's a 2002 89k 9-3 with a Nordic 3+ tune and all requisite hardware but the upgraded IC. I have been running this ECU for the last 4 months or so without any issues. Within the last week Amul numbers began to climb over the usual +500s territory. So much so that it hit +2045 yesterday while merging from an on ramp and later falling back to 1800s. MAF is original but seeing that both requested and calculated air numbers are pretty much identical, I'm assuming it's working well? New fuel filter was just installed and rear O2 sensor cleaned. Suspecting faulty FPR, I pulled the 3.5bar out (bought new from GS Taliaferro ) and swapped stock unit back in just to see if there was any difference. None, Amul still high. WIS points to a faulty MAF, low fuel pressure. Is there anything else I should be looking at? Would really like to bring it under control.
Appreciate any suggestions. Thanks !
tomaszewski is offline
Old 09-03-2013, 10:17 PM   #2
DrewP's Avatar
Often it's the AMM / MAF.
DrewP is offline
Old 09-04-2013, 06:24 AM   #3
Wagon Shaggin'
Saabeh's Avatar
Try cleaning the MAF and re-adapting the ECU. If it still persists, find someone with a good working MAF you can test with.
Saabeh is offline
Old 09-04-2013, 08:07 AM   #4
rabbit's Avatar
Put the 3.5bar for back in and test pressure at the rail. With the stock 3bar you will see a high amul for sure.
It could also be the MAF, give it a good cleaning and/or swap a known good one if you can.
Sent from AutoGuide.com App
rabbit is offline
Old 09-04-2013, 08:17 AM   #5
Thanks guys !
I will check the fuel pressure. As per MAF, I have a used back up unit and it's also showing nearly no deviation between calculated and requested air so I'm assuming it works well. I'm running injector cleaner as we speak.
Additional question: what is the hose that enters throttle body at the back right under the limp solenoid? I see some light cracking in it and I'm wondering if this could affect my A/F.
