saab catalytic converter removal model 9-3 2000 turbo - The Saab Link Forums
Old 07-20-2013, 04:58 PM
I have saab 9-3 se 2000 with 2.0 turbo engine. Please let me know if catalytic converter removal will flash check engine light, will it affect engine electronics? Both sensors are located before catalytic converter.
thanks
leezee is offline
Quick reply to this message
Old 07-20-2013, 08:22 PM
Ninety5Aero's Avatar
Doesn't the 2000 have 2 cats?
Ray
2000 Viggen 'vert
2000 9-5 Aero
1998 9000 CSE Turbo
1994 9000 Aero
Ninety5Aero is offline
Old 07-21-2013, 05:04 AM
I am pretty sure it just one, located right under oil pan, way too close. It cooks oil, which eventually turns into sludge, sludge clogs sump.
My point is to put straight pipe and wrap it with heat radiant tape, plus maybe gain a few hp, run turbo cooler...?
Also, I was thinking about installing lower temperature thermostat, original 195, to 180..
leezee is offline
Old 07-21-2013, 07:02 AM
soccerrplyr's Avatar
It has two, a small one at the top where the downpipe connects to the turbo and a larger one by the oil pan. You'll need to trick the ecu o2 signals with a tune if you try to get rid of the cats
1999 9³ Stage 18t
2000 9³ Stage 19t
2005 CRV
soccerrplyr is offline
Old 07-21-2013, 07:27 AM
ok, what if I leave 1st, and get rid of 2nd one, which is right under the oil pan?
leezee is offline
Old 07-22-2013, 06:55 AM
ok, catalytic converter removed, straight pipe put in plus aluminum plate to protect oil pan. so far, after 2 days of driving no check engine light is on. saab has 41000 miles.
here are pictures what I found in oil pan:
leezee is offline
Old 07-22-2013, 09:44 AM
Are you not in the US?
Over here, we have 2, and one is before the oilpan, and I *think* the other is behind the oilpan.
It's safe to say that your coding is different over there, especially if both O2 sensors are before the catcon.
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 07-22-2013, 10:16 AM
canada.
maybe you right, my saab had two catalytic converters, one is angle shape another under oil pan. never thought that 1st one-angled, small one is a cat..
leezee is offline
Old 07-23-2013, 01:12 PM
Wrong solution. Clean your pan, install PCV fix #6, change your oil regularly. A lower temp thermostat likely makes your engine less efficient. It will have little effect on the turbo temp since the turbo sits in the hot exhaust stream. Meanwhile you're polluting the air your kids will need to breathe, but what the heck, screw 'em.
You should be looking at a 3" downpipe with a race cat, a tune, and other mods if you want more HP.
BobSabbert is offline
Old 07-24-2013, 09:09 AM
I took out the 2nd cat and I have no check Engine light
shook187 is offline
Old 07-24-2013, 07:33 PM
let us know a little about your saab: any issues with sludging, how many miles, any special maintenance advice?
by the way, what did you do with 2nd cat, did you sell it to recycling yard?
leezee is offline
Old 07-25-2013, 05:41 AM
look at my art...jesus
leezee is offline
Tags
catalytic converter
