Any good head rebuilders near Nashua - Lowell? - The Saab Link Forums
Old 07-04-2013, 05:31 PM   #1
What I thought was a blown turbo -- constant oil smoke, visible oil seeping from the downpipe -- is actually an issue with the head.
Took off the manifold to reinstall turbo with new CHRA ....and the No. 4 exhaust port was caked with wet oil. So...I'm thinking bad valve seals/bent valve...
Question 1: It's a B234 head. I have a B235 sitting in the garage but will the comp ratio be too low? (90.5 pistons...)
Question 2: Any good head rebuilders in the Nashua/Lowell general area?
Old 07-04-2013, 06:03 PM   #2
NickTurbo900's Avatar
I have a good head rebuilder in the Barre, VT area. We use them for 25+ SAAB, Subaru, Volvo, and Mini heads a year. Never had a problem. Let me know if I can help.
NickTurbo900 is offline
Old 07-04-2013, 06:20 PM   #3
Thanks, Nick....Pending any replies, I might hit you up for that info!
Old 07-04-2013, 08:01 PM   #4
I would talk to Yankee Garage in Amesbury, MA.
978 346 7473
Mike
MickeyM
2006 Aero convertible
2000 9-3 silver convert (for sale)
mickeym is offline
Old 07-05-2013, 04:43 PM   #5
132417SAAB's Avatar
nashua engine re builders
603 883 1200
15 rail road square nashua nh (back of building)
he's both miked and I's go to guy for such needs. I give him an A+ for customer service and turn around time
99 9-3 se
91 Plantana Grey Carlson 9k
132417saab™©
AKA "numbers"
132417SAAB is offline
Old 07-08-2013, 05:41 PM   #6
Serendipitous timing on that post there, Mike S. Sorry for your woes, but as you might have gleaned from recent posts I am in a related situation. Now, the question comes to cost. Anyone have a ball-park for this sort of thing? I know to have it ported/matched is $$$$...
-Cm
Cm452 is offline
Old 07-08-2013, 06:06 PM   #7
I talked with one of the guys at Nashua and while he wasn't able to tell me an exact estimate, he gave me a ballpark that was what I expected. Disassembly, cleaning and inspection, and a valve job would be about $400, plus any replacement parts if needed. Based on the amount of oil in the No. 4 cylinder, I think I'm looking at at least one new guide and seals. I'll know more when I get the head off.
Old 07-08-2013, 06:43 PM   #8
byastremski's Avatar
Why not buy another head? With everyone that parts these cars out, heads should be a dime a dozen? Did you have upgraded valves springs in yours or something mike?
2001 Viggen BCB stg1
byastremski is offline
Old 07-09-2013, 05:11 AM   #9
Yep...you nailed it. I have the stiffer Volvo springs in it, and new seals.
So now I'm trying to figure out if it's worth it to just get the Volvo springs put in the B235 head and have that rebuilt instead of the busted B234.
Old 07-09-2013, 07:15 AM   #10
Aren't the intake manifolds completely different? As far as the ports and such? Are you going to machine out your T5 manifold or something?
Probably worth staying with a T5 head and getting it port and polished...
You gotta figure if you're going to a T7 head you would need virtually all the internals of a T5 head transplanted into the T7 head to get rid of the "pencil size" valves...
Better bang for buck is get another T5 head done up with new springs at the cost of $80 for the springs, a shop will probably charge more to take them out.
Old 07-09-2013, 07:35 AM   #11
Dave's Machine shop in Fitchburg always did mine.
Good prices, great work.
I think I paid $350 for a completely rebuilt head. (seals, guide adjust, valve job, bake, plane, and remove/replace broken manifold studs)
$99 for just a bake/plane.
I guess the NAPA in Townsend does good work, as well. (only by word of mouth)
also.... *told ya*
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 07-09-2013, 08:16 AM   #12
That's all solid info....
Old 07-09-2013, 04:41 PM   #13
Marks9-3's Avatar
Got mine done in northern CT. Payed ~$110 for deck, cleaning, and new valve seals installed (supplied the seals). Have the invoice laying around. They were referred to me by others.
Marks9-3 is offline
Old 07-09-2013, 05:56 PM   #14
Pulled the head tonight and Yay!!!!....there are nicks in the tops of the pistons from the intake valves. So, now I'm betting that the oil coming from No. 4 is from a guide or seal knocked out of place...
