3.5 fpr ? - The Saab Link Forums
Old 05-10-2013, 09:06 PM   #1
jack 9-3SE's Avatar
Send a message via MSN to jack 9-3SE
Cool 3.5 fpr ?
Hey guys I bught this 3.5 fpr here:
FUEL PRESSURE REGULATOR SAAB 9-3 9-5 900 9000 2.0 2.3 2.5 TURBO 3.5 BAR | eBay
what you think?
jack 9-3SE is offline
Old 05-11-2013, 12:09 AM   #2
You are going to need a tune for this to work properly...
This is because you are going to go rich and the ECU will not like that.
I confess that I don't know if the ECU can effectively adapt (<=20%) for the difference in flow. You might be able to get it to run OKAY...
Why did you buy it? The stock one is 3.0BAR.
-Cm
Cm452 is offline
Old 05-11-2013, 05:22 AM   #3
Marks9-3's Avatar
Pretty sure that while T5 tunes eventually need the 3.0bar MAP sensor, the T7's use the 3.5bar FPR instead.
Marks9-3 is offline
Old 05-11-2013, 05:41 AM   #4
Wagon Shaggin'
Saabeh's Avatar
This requires a tune. Get in touch with Mike D.
Saabeh is offline
Old 05-11-2013, 10:46 AM   #5
While I am not 100% on the T7, I know for a fact that T5 uses a 3.0 bar regulator and I am inclined to believe that T7 does as well.
-Cm
Cm452 is offline
Old 05-11-2013, 01:40 PM   #6
jack 9-3SE's Avatar
I am going to Stg 3.....
the 3.5fpr I bought don't have any company name on it,all that is written is 3.5bar
Old 05-11-2013, 08:12 PM   #7
Marks9-3's Avatar
-Cm
Differences come to play in how the engine management works. T5 is based off air pressure, while the T7 is based off air in the system and desired HP output and due to this, their needs are different. I'm about 99% sure that T7 doesn't have a MAP sensor.
Marks9-3 is offline
Old 05-12-2013, 04:15 AM   #8
lms
A T7 does have a MAP, it's just not used like one is in a T5 since a T7 has a maf and a T5 doesn't.
There were a whole bunch of post years ago about adding a 3.5 to a car that had a 3.0.
I'm pretty sure the answer was that in order to get the full benefit of installing one, you would have it tuned. But if one were to just throw it on, T7 was smart enough to adapt to it but with no gain. If you have a wideband I would plot a/f and fuel trims with both after 200 miles of driving and see what really happens. Why 200 miles, because it is stated that if you unplug the battery, it will take about that many miles of everyday driving for a T7 system to fully adapt.
lms is offline
Old 05-12-2013, 05:12 AM   #9
mike d's Avatar
comparing a MAP to an FPR is apples to oranges. an FPR basicly increased the flow rate of your injectors. doing so will make it run kinda crappy untill software has been adjusted
MikeDTuning.com
mike d is offline
Old 05-15-2013, 04:52 PM   #10
I've bought 2 FPR's from various places (Genuine Saab, eBay) and none of them fit the 9000 Fuel Rail. The small nipple is always too big to fit inside the Fuel Rail on my 9000. Please let us know.
vt9000cse is offline
