LinkBack | Thread Tools |
#1 |
Riddle Me This
Took two friends out to show them what my car had to offer in terms of acceleration. On entrance ramp to highway, up hill, I booted it in 2nd(60% throttle). It spun the tires easily, but then this whistle/whine/metallic high-pitched ringing noise came on progressively louder and steadier as revs and boost did.
In the heat of the moment, I thought it might have been noisy PWM drivers from the ECU, which can, on occasion, be heard or some part vibrating against something. I also asked a friend to check that the lines from the water/methanol weren't kinked and that the reservoir had fluid in it ( about 1/3rd tank left). He confirmed this. So I gave it ~70% throttle in 3rd and 4th, only to again have the noise come back. So, we high-tailed it back to his garage where we found nothing, on the computer from the logs or mechanical. Two hours later I drove home and tried to replicate the sound; nada, even at WOT. The next day, I had one friend get in the car and we tried to get the noise to come back, again, no noise. No one could pin point where the noise was coming from. Wasn't the back seat where the w/m pump&tank are, nor did it seem to be coming from the turbo. I don't think it was the clutch slipping and making noise either, as the revs matched the speed. Anyone have any ideas? It kinda sounded like this, but lower and less whistly/airy. https://www.youtube.com/watch?v=UEvtLlikdc4 Thanks, -Cm
T5 Suite Stg GpopT28, Deka 630's, Walbro 255LPH, 3 bar MAP @ 1.92Bar, W/M, Stg2 clutch, full suspension/bushes, 308mm brake upgrade, 3" turbo-back, big-azz FMIC &Oil-cooler, and fwdlol diapers. |
Sponsored Links | |||
#2 |
Interesting, it was metallic sounding? Unless you can replicate I would not worry. My 900 made all kind of noises then the next day they would be gone, just the attitude of these cars. If it comes back take a look at the pulleys/WP/turbo/BCV. My BCV likes to make a rap-rap sound at like 1500rpm in vacuum.
Current Cars
2010 Mini Cooper S 1991 Miata 1995 900 SE Turbo |
#3 |
What's the suspension setup on your car? Lowered? Long shot, but maybe something to do with the extra weight plus the ass end squatting when you go WOT.
#4 |
Wheel bearing .......*Guessing*
B.L.T.H ... Brake late, Turn hard |
#5 |
So effing random, but this is a better approximation of the tone..kinda reedy, but such that once at sufficient frequency it produced a whine. It started out reedy too...
###vbulletinsuckspleasecopyandpastelinkhttp://www.youtube.com/watch?v=ug64rZESK-Y&t=0m20s -Cm Edit: So, I made a link that goes right to the time in question in the ridiculous video I posted, so there is no fiddling. You need to post the entire http----etc,etc. It links to the 20 second mark of the video. Vbulletin just embeds the video but doesn't include my fancy address coding to omit the first half of the video...\rant
T5 Suite Stg GpopT28, Deka 630's, Walbro 255LPH, 3 bar MAP @ 1.92Bar, W/M, Stg2 clutch, full suspension/bushes, 308mm brake upgrade, 3" turbo-back, big-azz FMIC &Oil-cooler, and fwdlol diapers. Last edited by Cm452; 04-29-2013 at 12:39 AM. Reason: Vbulletindurrrr |
#6 | |
-Cm
#7 |
Awesome boost 1.92 Bar?
#8 |
you think it was a turbo/pressure related sound?
-Cm
#9 | ||
How recently have you done your idler pulley's and whatnot?
#10 | |
The consensus is that those in the car (including myself) believed the noise to emanate from the passenger footwell area. This is not entirely helpful, as the glovebox is gone, which tends to funnel noises from the engine bay to the cabin. -Cm
#11 |
![]() Join Date: Jan 2007
My viggen will make almost a whistle/whine under full boost in 2nd and sometimes 3rd gear. I think it's air coming from the throttle body to upper pipe connection. If I were you, I would do a boost leak test on the car.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#12 |
Did you have your cabin fan on?
My fan makes strange noises from time to time ...... Then goes away
#13 |
Had a similar noise turned out my gasket to the turbo/manifold was leaking slightly
97 9000 cse stage x Holset hx35w 330whp 373lbft sold 09the VW GTI day stg 1 |
#14 | ||
If it is one of those pulleys, it will let you know for sure soon enough.I actually was able to cross ref. my original replacement thread on SC with when I had it fail 4 or so years later.
#15 |
Sounds like a pulley
Daily Driven '00 Saab 9-3 Bone stock To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. SOLD '97 Saab 900SE Stock 2.0 Holset HX35 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. -Branden |
#16 | |
![]() -Cm
Sponsored Links | |
Thread Tools | |
