Lets talk real$ - The Saab Link Forums
Old 04-20-2013, 04:31 AM   #1
Lets talk real$
So with the new advance in tune I know that my viggens week t7 pistons will need to be babied. So I'm trying to find out what pistons should be placed in and what's a realistic price, so I can get ready.
Also dose any one have any step by step oil pan dropping instructions?
hvaclander is offline
Old 04-20-2013, 04:37 AM   #2
bogan's Avatar
Flick thru this : Dropped the oil pan (56k, forget it) - SaabCentral Forums
bogan is offline
Old 04-20-2013, 04:59 AM   #3
nowhereman's Avatar
here try this
Saab Forged Pistons
or this
Genuine Saab Pistons Forged JE for B235 $519
2008 9-3 SS: Stg 1
nowhereman is offline
Old 04-21-2013, 02:33 PM   #4
Any one with experience regarding the cost to have pistons installed? That part of his question is a good bit harder to find when searching.
The_Ridge is offline
Old 04-21-2013, 04:43 PM   #5
Are you trying to find the cost for other parts needed (gaskets, etc) while you install the pistons yourself?
Or are you asking us what your mechanic would charge?
Sent from AutoGuide.com App
Used Saab Parts:
'92 9000T, 5MT, Black
dantinne is offline
Old 04-22-2013, 04:32 PM   #6
I was thinking more of the labor side. Maybe the OP wasn't concerned with that part. I've always thought the pistons were just the edge of the ice berg when it came to engine builds.
Old 04-23-2013, 03:20 AM   #7
Count on the pistons and rings costing about $500. New head gasket kit is likely another $85. With the head off, it's a good time to do the timing chain and tensioner, so that's another $80 in parts.
Labor cost is dependent on the hourly rate near you, which varies pretty wildly depending on the region. Figure on the labor rate being anywhere from $65-90 per hour.
Rough estimate is about 8-12 hours labor (that's probably on the high side...)
Old 04-23-2013, 07:24 PM   #8
Thanks all I was just trying to find out how much I need to get up to in my second account befor doing this job.
Old 04-23-2013, 08:54 PM   #9
gdc
wait , mechanics in Mass , charge 65 dollars , wow , sf and anywhere near is atleast 100
gdc is offline
Old 04-24-2013, 05:00 AM   #10
LOL...I left an intentionally wide range there. Labor rate outside Boston is usually between $80-90, and that's at a decent indie. Closer to the city it pushes $95-100...
If you're in EBF somewhere, the rates are often lower. There was a thread a few years back where guys said their local indie charged $50-60
Old 04-24-2013, 10:48 AM   #11
JZW
Something not mentioned here, the Woessner pistons are known for much less piston slap than the JE pistons, the Woessner are lighter and of much higher quality in my opinion, these are the pistons used to upgrade for cars like Porshe and I have found they work very well, much less noise on start up and the performance is great. I use them for all my engine builds, even my 800bhp drag car,
John
JZW is offline
Old 04-24-2013, 03:04 PM   #12
Thumbs up
If you going to put pistons in, and your going to do it right, take it to a good mechine shop. Make sure they balance the rotating mass, etc. Then you might as well deck the block and while your bottom end is @ the shop you might aswell get a basic valve job. With pistons, rings, timing parts, and every new gasket. Your looking just over a grand, IF YOU DON'T FIND ANYTHING ELSE WRONG WITH YOUR ENGINE. im looking to do the same thing, but Im a tech and have access to a shop so I will be re-assembling the engine myself. keeping my labor cost down and prying my engine was well taken care of. And this is a bare minimum imo, why put 500$ pistons in a car with worn out head or bottom end? If it goes you'll have to buy new pistons again.
I'm in the same boat, ive got the pistons and rings, now I just need the rest of my funds and 3 to 6 spare transmissions..... It's going to be dope :$
LordScania is offline
Old 04-24-2013, 03:56 PM   #13
Cark's Avatar
My indy is $60 per hour, and he knows his shit, and charges you actual labor, and not what the book says it takes for time. He can usually bang out most jobs pretty damn quick, and 9 times out of 10, he winds up being even cheaper than what he quotes you.
08 9-5 Aero S/C
85 900 turbo - T5
Cark is offline
Old 05-01-2013, 02:41 PM   #14
On the engine I just rebuilt I had the block: Cleaned, Decked, Bored .020 Over, the Crank Balanced, main bearing housings line honed, magnafluxed, the rods and pistons balanced, and had them make a balance shaft delete kit.
I had the head cleaned, milled, pressure tested, valves lap'd in, valve seals removed.
Total was around $1300 for machine work alone.
Thanks,
Joe Reichard
10 Saabs
1 Mercedes
Complete Addict.
Slow Joe is offline
