A little nervice - The Saab Link Forums
Old 04-13-2013, 08:09 AM   #1
A little nervice
Is a stage3 viggen daly driver a safe thing? I have every thing that you need for it on the car.
3" dp with bsr cat back
Ets ic
Gs cold air in take with gs cobra pipe
Forge deverter valve
New silicone hoses
New control arms with poli bushings
22mm rear sway bar
Upper strut brace
Stearing clamp and brace
6 point subframe brace
Aem turbo psi gauge
Aem wide band gauge
I believe that's every thing I have the tune and the fpr ready to go I wA just wondering if any one has a stage 3 set up and how they feel.
hvaclander is offline
Old 04-13-2013, 09:05 AM   #2
soccerrplyr's Avatar
sounds good..but what about cams
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
soccerrplyr is offline
Old 04-13-2013, 09:27 AM   #3
I have no clue how to put those in and there are no other Saab people in my Area.
Old 04-13-2013, 10:26 AM   #4
Cark's Avatar
why cams for stage III? I know they CAN be changed to the T5 cams, and some people like the extra breathing up top, but from what I understand they are not for everyone.
08 9-5 Aero S/C
85 900 turbo - T5
Cark is offline
Old 04-13-2013, 10:44 AM   #5
WSW
WSW's Avatar
You are all ready for stage 3.. Cams aren't a necessity
99 Viggen
04 9-5 Aero Wagon
WSW is offline
Old 04-13-2013, 12:47 PM   #6
byastremski's Avatar
perfect daily driver, its when you go passed that you start breaking shit... There are some guys up in new jersey that could walk you through changing cams if you ever wanted to... its very easy...
2001 Viggen BCB stg1
byastremski is offline
Old 04-13-2013, 01:30 PM   #7
Ok ok sounds like I will be ok with this set up looks like Monday there will be another stage 3 viggen in the world
Old 04-14-2013, 06:59 AM   #8
RBatsch's Avatar
Nordic stage 3 Viggen for 8 years and now stage 4 for past 2 years and the car is a great daily driver, winter or summer, -40C - +40C, whatever, it just works and feel like a regular Viggen.....until you step into it!! So glad I did this years ago....
Looks like you're all set...go for it!
RBatsch is offline
Old 04-15-2013, 09:20 AM   #9
So everything's on the car and now it will not start !
Old 04-15-2013, 09:45 AM   #10
SPG-GASM's Avatar
What did you most recently do? Did you have "your" ecu tuned? Or was it another one? If not your original the immobilizer code needs to be learned to the new ecu.
SPG-GASM is offline
Old 04-15-2013, 10:30 AM   #11
It's the stock ecu every thing should work!!!
Old 04-15-2013, 10:39 AM   #12
SPG-GASM's Avatar
You have to be clear to us, so we can help you.
What work was just done to the car, if any?
Have you checked for fuel pressure? Is there 12v at the pump?
If you have fuel pressure, check your do with another one.
SPG-GASM is offline
Old 04-15-2013, 10:55 AM   #13
did you plug the ignition cassette back in?
did you plug the crank sensor back in?
Doesn't look like you installed anything that would cause a car to not start, really.
Does it crank and then do nothing?
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 04-15-2013, 10:58 AM   #14
gm
gm's Avatar
Like stated the immobilized or whatever its called needs to be setup for your car. Did you buy someone else's ecu or did you get it from a company who sells them?
I have been SPG 3 or 3+ for I think close to 10 years now. Several years ago I added a -18t turbo and t5 cams.... Wy the car didn't come this way from the factory we will never know. Feels far superior to stock
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 04-15-2013, 11:04 AM   #15
Ok so I drove the car in to my drive way from this am with a stage one ecu. I put the 3.5 fpr on and then the stage 3 ecu when to turn it over and it did not start. It cranks just fine sounds like the pump is on when I turn the key and I see the ecu is in locked on the Sid screen. Called the tuner to see if they did not type in the code right on the ecu. It wa the stock ecu that I shipped them to tune. So I'm at a loss right now
Old 04-15-2013, 11:08 AM   #16
Just checked the fuel rail there's gas there so the new fpr is letting gas in
Old 04-15-2013, 11:28 AM   #17
Jaws's Avatar
It's got to be the ECU or FPR so check the FPR wiring and hopefully your tuner can verify the ECU. You may need to put back the Stage 1 ECU and remove the FPR as a sanity check.
Jaws is offline
Old 04-15-2013, 11:46 AM   #18
Just put the car back to stage one and the stock 3.0 fpr on and the car started right up..... Sooooo Im guessing its the tuner
Old 04-15-2013, 01:31 PM   #19
nowhereman's Avatar
its the immobilizer code for the ECU. you have to have it "learned" to the new car/married to the car. when you sent the ECU out did they get your VIN? if not that is likely the problem
2008 9-3 SS: Stg 1
nowhereman is offline
Old 04-15-2013, 04:26 PM   #20
Dose any one have the jzw ppc tuning just saw it looks neat.
