since im rebuilding my front end suspension - The Saab Link Forums
Old 03-27-2013, 10:16 AM   #1
Easily's Avatar
i believe that i might as well go all out and use poly bushings. i know I'm being lazy buy how much estimated would it cost to do this?.
just looking for peoples thoughts that have done this already
any input/info would be appreciated
Timothy Morath
97 saab 900se
99 9-3
Easily is offline
Old 03-27-2013, 01:31 PM   #2
VWSAABVT's Avatar
how much would it cost to have done or to do yourself?
stg 5 99 9-3 coupe
96 900se sold
VWSAABVT is offline
Old 03-27-2013, 06:20 PM   #3
Easily's Avatar
to do myself
Timothy Morath
97 saab 900se
99 9-3
Easily is offline
Old 03-29-2013, 09:46 AM   #4
pitman's Avatar
if you make your own bushings with tools you own it will be alot cheaper than buying them.
but they make aftermarket bushes too. i would say if you already have tools and a press buy a cheap lca and press your own.
or gs sells the lca's with poly and upgraded bolts for $400+ then you need tie rod bushes and steering rack bush. plus any other bushes they make now
you could spend thousands re doing the suspension if you dont want to over look anything. esp if you trying to get performance.
pitman is offline
Old 03-29-2013, 09:49 AM   #5
I posted recently that I found a GREAT seller on ebay that's selling poly bushings from PPS for extremely fair prices.
He has a hanful available now, but I've emailed him, and he's able to get anything in the PPS catalog within a couple weeks.
Might be a good option if you're on a tight budget.
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 03-29-2013, 10:06 AM   #6
Putting the bushings in is a royal PITA. Find someone with a hydraulic press and pay them to do it.
If I had it to do all over again, that's what I'd do. Cutting out the metal sleeve sucked balls.
Old 03-29-2013, 07:18 PM   #7
Easily's Avatar
ic
Timothy Morath
97 saab 900se
99 9-3
Easily is offline
Old 03-29-2013, 09:13 PM   #8
Marks9-3's Avatar
The Gen Saab ones are 2 piece so you don't need them pressed in. You just new to have the old ones pressed out.
I'm pretty sure eeuro is starting to sell poly bushings for our cars. Thought I read that in an email.
Marks9-3 is offline
Old 03-30-2013, 05:50 AM   #9
If EEuro is selling poly bushings, I'm certain they'll be the same PPS that the seller turbo) has on Ebay. They'll likely be twice the price, though.
Craig R.
g96nt is offline
Old 03-30-2013, 07:46 AM   #10
Marks9-3's Avatar
Saab Control Arm Urethane Bushing Kit | Proparts Sweden 61340110PU | Free Shipping
Here is one of the Control Arm bushings for $21.45, they are the same PPS ones. Not sure what what they go for on eBay but they can't be all that much cheaper. Just simply putting another option out there.
Marks9-3 is offline
Old 03-30-2013, 08:40 AM   #11
Easily's Avatar
those are the inners?
Timothy Morath
97 saab 900se
99 9-3
Easily is offline
Old 03-30-2013, 09:54 AM   #12
Marks9-3's Avatar
Na, they are the outter ones between the stanchion arm and where it connects to the control arm.
Marks9-3 is offline
Old 03-30-2013, 10:04 AM   #13
Yep....taking out the bushings was the part that sucked ass.
Old 04-02-2013, 12:29 PM   #14
sallythesaab's Avatar
I'm pretty much replacing my front and rear suspension. Grabbed new control arms/balljoints along with poly kit from GS. They didn't make all the bushings I needed at PPS/eBay and the Powerflex sells them individually. GS ended being a pretty good deal for the package, $108. Looks like the polys from eEuro are temporarily unavailable. I'll be pushing/cutting the new bushings out and replacing with polys very soon. I've decided that I'll just do it myself instead of finding a press. I kinda live in the middle of no where.
2004 9-3 SS Linear (SOLD)
2003 9-3 SS Linear
2002 9-5 Aero Wagon
2002 9-3 SE
2002 9-3 SE Vert
1999 LB 9-3 Viggen
1996 9000 CSE (RIP)
1990 9000 S (SOLD)
sallythesaab is offline
Old 04-02-2013, 01:12 PM   #15
Marks9-3's Avatar
When I did mine, I bought new control arms through GenSaab for the genuine part. Not a knock off and they pressed out the bushings for me.
Marks9-3 is offline
Old 04-02-2013, 03:37 PM   #16
Believe they have Scantech's now.
2003 9-3 SS Linear
2002 9-5 Aero Wagon
2002 9-3 SE
2002 9-3 SE Vert
1999 LB 9-3 Viggen
1996 9000 CSE (RIP)
1990 9000 S (SOLD)
Old 04-02-2013, 04:10 PM   #17
Marks9-3's Avatar
That's a bummer. I got mine a while ago.
Marks9-3 is offline
Old 04-02-2013, 07:24 PM   #18
gdc
cut the sleeve with a hack saw a new blade is nice but not necessary. the first one took me 20 minutes after i used a gear puller to separate the rubber part , the second one even faster. the GS package at 108 it is fairly cheap and easy and made the car surprisingly a lot tighter than before.
gdc is offline
Old 04-03-2013, 10:52 AM   #19
Easily's Avatar
well i have a set of new control arms already, and i'm doing the outer/inner/swaybar mount & endlink bushings, and its gunna be scary cutting into the stock bushings to accomadate for the poly bushings o_O. shoulda woulda coulda with the GS stuff but i wanna do it myself. i also ordered a set of vogtland springs from GS that will be here tomorrrow but once i bought them i figured that i would might as well replace the bearing plates and struts. i cant afford koni stuff right away im on a budget, (fixing up a house) whats a good sportish strut assembly i can use? (i work for advance auto parts) and i sell alot of monroe stuff but has anyone had any experence with it? (results vs stock)
Timothy Morath
97 saab 900se
99 9-3
Easily is offline
Old 04-03-2013, 11:02 AM   #20
I'll have some used ones off my Viggen soon. Not sure what brand until I get them off. Still in good shape, just decided to upgrade to Koni/Eibach setup.
2003 9-3 SS Linear
2002 9-5 Aero Wagon
2002 9-3 SE
2002 9-3 SE Vert
1999 LB 9-3 Viggen
1996 9000 CSE (RIP)
1990 9000 S (SOLD)
