Question - The Saab Link Forums
Old 03-09-2013, 02:43 PM   #1
Question
So I tied In my turbo gauge today and I think that it drawing to much Juice. I have my wideband and turbo tied in to the dimmer switch. Like every one said to do. The gauge keeps on resetting so that's why I think that's its drawing alot of power an cutting out some times.
Also what's a realistic turbo psi should i be getting on a w.o.t.
hvaclander is offline
Old 03-09-2013, 03:56 PM   #2
132417SAAB's Avatar
anything between 5 to 25 psi. Without even knowing what car you have let alone what modifications if any no one can tell you. Also what kind of boost gauge do you have?
99 9-3 se
91 Plantana Grey Carlson 9k
132417saab™©
AKA "numbers"
132417SAAB is offline
Old 03-09-2013, 04:50 PM   #3
nowhereman's Avatar
what he ^ said.
and what do you mean resetting? is yours a digital guage with an electronic sender? if so the reset's could just be a loose wire somewhere or something like that.
2008 9-3 SS: Stg 1
nowhereman is offline
Old 03-09-2013, 07:31 PM   #4
It's a Viggen 3"dp 2.5bsr cat back. Ets ic, stage one. The gauge is aem turbo gauge. I will check the wiring tomarrow. I need to get a new a piller I don't like the way it came out I put them to far apart it looks less like a sleeper.
Old 03-10-2013, 06:56 AM   #5
whos the stage 1 tune by?
id guess maybe 18 to 20 psi?
but whoever wrote the tune will be able to tell you at least it should be in theory
Snowcat77 is offline
Old 03-11-2013, 05:10 AM   #6
rabbit's Avatar
Question
I thought you moved to a GS stage 3?
Sent from AutoGuide.com App
rabbit is offline
Old 03-11-2013, 05:47 AM   #7
mike d's Avatar
few more details here are needed, is the guage electronic or a manual style?
also, the dimmer circut is not a high amp setup, if this is used for anything besides back-lighting on the gauge, than it will not provide enough juice.
MikeDTuning.com
mike d is offline
Old 03-11-2013, 01:12 PM   #8
Not yet getting the car fully ready for the abuse of stage 3,just installed a 6 point.
Old 03-11-2013, 01:15 PM   #9
I was able to find out what was going on being that its tied in to the dimmer. If the dimmer is not fully up the its not supplying full voltage to the gauge hence cutting out once in a while.
Old 03-11-2013, 06:19 PM   #10
I'm going to skip both the smart remarks and humor and assume you're not electrically familiar
One side of the dimmer switch has 12v (input). The other side has variable output that dims or brightens the lights on the dash (variable output). If you tap into the 12v input side, you'd be OK. However, that's not a particularly high amp circuit - I would try something that's got a little more spare power for anything but another light bulb.
BobSabbert is offline
Old 03-11-2013, 06:25 PM   #11
Ditto to everything said above...
There's a constant power source wire in the main light switch. that's probably a better tapping source....
