stage 1 tune..or stage 2 - The Saab Link Forums
Old 02-12-2013, 07:05 PM   #1
Im interested in gettin my 97 vert tuned. it is basically stock other than the open intake and 2.5 inch exhaust turbo back with no converter.
I have read all about the taliaferro tunes and am aware that stage one is for stock hardware and stage two is for better exhaust systems and intercooler combinations.
considering my custom exhaust and intake what is best for the car.
bte its 2.0 turbo and im running 91 no ethanol or better
lespaullover13 is offline
Old 02-13-2013, 05:04 AM   #2
nowhereman's Avatar
first question....
is the car a true stage 0? meaning no issues everything like new, perfect operating condition?
if so you might as well go with stage 2, because stage 1 would just delay your bump to stage 2.
2008 9-3 SS: Stg 1
nowhereman is offline
Old 02-13-2013, 11:03 AM   #3
yah the car is 100%. Everything works like it should. Just finished the down pipe and exhaust and want to get tuned.
Also were can i get dyno tuned and much much does that normally run?
Old 02-13-2013, 11:11 AM   #4
You don't need a dyno to go Stage 2...save the dough...
Old 02-13-2013, 11:33 AM   #5
what id like to know is what the boost will max at for stage 1
Old 02-13-2013, 11:38 AM   #6
It's not much. IIRC, it's something like 15 psi...
Old 02-13-2013, 11:39 AM   #7
so stage two would surpass that. by how much
Old 02-13-2013, 11:41 AM   #8
Find a tuner, look at the HP output and go from there.
Old 02-13-2013, 12:00 PM   #9
Wagon Shaggin'
Saabeh's Avatar
Where are you located?
Saabeh is offline
Old 02-13-2013, 12:10 PM   #10
rabbit's Avatar
3" downpipe? If it is then go for stage 3. There really isn't a huge gain between stage 1 and 2 anyways.
Otherwise stage 2 should keep you happy for a little while.
Sent from AutoGuide.com App
rabbit is offline
Old 02-14-2013, 12:50 AM   #11
bogan's Avatar
Go straight to stage 3.
Ur gunna do it anyway. *trust me*
bogan is offline
Old 02-14-2013, 04:42 AM   #12
nowhereman's Avatar
very true. if you have the 3" DP might as well jump right in
even with stage 2 and basic stage 3 the numbers are pretty much known. no need for the dyno really. its when you get past that and really agressive that you start needing serious tuning.
2008 9-3 SS: Stg 1
Old 02-14-2013, 05:42 AM   #13
Ok great info everyone. I'm located in central ny what is the best bang for buck to get to stage three. What are my options. Are there others than taliaferro and Nordic or bsr
Old 02-14-2013, 05:44 AM   #14
Wagon Shaggin'
Saabeh's Avatar
Neither, it would cost you less money to get Mike D to come out there and road tune your car. If you can get 4 or 5 people who need work or tunes he would come out and do them all.
Saabeh is offline
Old 02-14-2013, 06:20 AM   #15
nowhereman's Avatar
are you kidding?
do a quick search keyword "tuning" on here and youll get lots of options.
mikeD, JZW, Nordic, GS, just to name a few.
2008 9-3 SS: Stg 1
Old 02-14-2013, 07:38 AM   #16
If I did get the stage 1 taliaferro upgraded ecu what would it require to go to stage two an three if I decided to
Old 02-14-2013, 09:11 AM   #17
Easily's Avatar
if u have a td04 go stg3 if u have a t25 garrett stay stg1 or 2
stg 3 is 3' dp crossflow ic td04 viggen clutch/pressure plate
Timothy Morath
97 saab 900se
99 9-3
Easily is offline
Old 02-14-2013, 10:47 AM   #18
TheSaabNinja's Avatar
Running Mike D's Stage 2 with a Genuine Saab Open Air Intake and a Viggen intercooler on my T25. its fun. once I get my downpipe though it will be worth it.
2001 9-5 Aero Clone Stage 1
2001 9-3 Base 15t swapped
TheSaabNinja is offline
Old 02-14-2013, 10:48 AM   #19
mike d's Avatar
Thanks for the plugs guys! NY is not to far away from me, and if a few people were to get together i would be happy to take a day and head out there!
talk with the people who are setting up your car, and read/ask around on how the car should be set up for what you want from it. there is alot more to a tune than just peak power output!
MikeDTuning.com
mike d is offline
Tags
intake, stage 1, stage 2, taliaferro, tune
