Sea Foam in a turbo engine? - The Saab Link Forums
Old 10-31-2005, 05:16 PM   #1
Editor
I ran Sea Foam in my last car, the 98 NA with no problems. I really think it made a difference. It was pretty noticeable. My question is, as long as I use a safe vacuum line, is it still ok to use Sea Foam on a turbo engine?
Les Bouquins is offline
Old 10-31-2005, 05:22 PM   #2
PaulH's Avatar
WTF is sea foam? thought that was a color
Paul
PaulH is offline
Old 10-31-2005, 05:25 PM   #3
DeLorean's Avatar
it's some kind of engine treatment / injector cleaner. I think it's similar to "marval mystery oil"
I doubt it could hurt anything but I always wonder about what, if anything, gas and oil additives do.
DeLorean is offline
Old 10-31-2005, 05:27 PM   #4
PaulH's Avatar
yeah id keep an eye on the warnings on the bottle, might do funny things with the turbo, i know that most if not all engine oil flushes say specifically not to use them on turbo cars.
Paul
PaulH is offline
Old 10-31-2005, 05:28 PM   #5
Editor
I think it made a difference in the NA... I'll just have to try it and see.
Old 10-31-2005, 05:42 PM   #6
DeLorean's Avatar
Paul
they say that because of the high oil temps in turbo cars. you could very well catch your oil on fire and have the engine quite literally explode!
now that's only with the engine flush, which is basically kerosene
DeLorean is offline
Old 11-01-2005, 07:30 AM   #7
I have heard it is not a good idea on turbo cars. It can damage the turbo.
nbndtrain is offline
Old 11-01-2005, 09:00 AM   #8
BurnsSide42's Avatar
MOST additives are bad if used more then once... but on the other hand MOST additives don't do shit other then fuck shit up later in life. Read the "contains:" if you see ANY form of Alcohol in the bottle - don't buy/use it. It will do nothing but fuck things up man.
A few KNOWN GOOD additives are Chevron - with Techron (injector cleaner)
Anything made by Chevron - good stuff
Another thing to look into - GM Top Engine Cleaner - shit works, and is VERY hazerdous (sold at any GM Dealership) But I'll post a how to sometime on that stuff - it's awesome shit. Cleans EVERYTHING on the top end of your motor overnight! (and it's proven to work!)
Addatives - just be cautious as to what you "toss into your car"
Check out
for your repair needs
BurnsSide42 is offline
Old 11-01-2005, 09:09 AM   #9
Trollerator
abdukted1456's Avatar
so methanol, would that clog a cat?
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 11-01-2005, 01:17 PM   #10
No, just corrode all your fuel lines if you use it often. Though it's a lot less harmfull when there is no water.
Also, ethanol isn't as harmfull as people think. Most Saabs are designed to be able to take 10-15% by volume. And many cars, such as WRX's, need only have their injectors changed to run on E85, which is 85% methanol.
Meh
SaabTuner is offline
Old 11-01-2005, 02:03 PM   #11
VAGGEN's Avatar
I've heard really good things about BG 44K and I have seen it on a Saab mechanic's bench at the dealership. It was recommended to me a while ago, but that stuff ain't cheap! At $20.00 a bottle, it better wash and wax my car too!
Anybody know anything about it?
2004 9-5 Aero Wagon - SOLD - and missing it
2004 S2000 - 31,000 miles and counting much more slowly
VAGGEN is offline
Old 11-01-2005, 02:19 PM   #12
Passion4_900's Avatar
Send a message via MSN to Passion4_900
As far as an engine flush on turbo cars, I remember reading that certain ingredients in an engine flush product can actualy "cook" on the turbo's bearings and obviously seize the turbo.......
As far as fuel injector cleaner, I would think it is harmless (read the label) but regardles of what the label says, any aditives you put in the fuel for whatever reason it is, it may throw a CEL as the ecu detects abnormal combustion or something...... had that happen with an octane booster.....
- 2010 Camaro SS Cyber Grey - parked for the cold months
- 2001 9-5 2.3t - finally on the road
Passion4_900 is offline
Old 11-01-2005, 05:04 PM   #13
I love MOST of B&G's products (as they cost me nothing ) and I tend to have "extra's" at times. The alcohol limit is 10% as a rule of thumb for ALL cars. Once you exceed that limit - you begin to damage your injectors and the fuel lines. You want a alcohol powered Saab - convert the fuel system! (but the fuel costs are much more then petrol per gallon - near $20 a gallon) Near Atco NJ (the race track and town) there are pumps which have 103 Octaine still and it's not cheap - but it's safer then addativesby about 100 track pulls.
Check out
Old 11-01-2005, 05:19 PM   #14
I love BG 44K, the stuff is awsome!! It is completely worth the 20$ I like putting it in and then watching the MPG increase on the SID, its my little part to help my wallet and the environment. Seriously though, the stuff works, just try it, I mean, you can barely get half a tank of gas for 20$ these days I also tried the BG oil additive ( I was getting a little bit of lifter noise and "clicking" on start up) I was a little apprehensive at first because it had the consistancy of mollases or honey, kinda looked like honey too. But I figured since I am running 10/30 Mobil 1 full synthetic it would be ok. It completely got rid of all lifter noise and the pesky "clicking" that I was slowly convincing myself was the timing chain As for any effect on the turbo, I can not be certain because I have now upgraded to a GT series turbo, but my old T25 with over 100k miles still spins fine with very minimal shaft play, also consider the fact that I am very peculiar about my oil changes (every 3k miles no matter what). Just thought I would share my experiences.
I also run Marvel Mystery in my SPG, although I can not really say if it has helped tremendously, but it has had no ill effects (in the gas, not the oil). I tried it because the guy at SOC with 965+k miles on his car, im sure everyone who reads nines or was at SOC knows who I am talking about, swore by it, and also swore by using Mobil 1 supersyn in the tranny- havent tried that yet though- even though I probably wont.
1995 900se GT3071 E85 Stg. Fun
1985 900 SPG- Hibernating
Saabn is offline
Old 11-01-2005, 10:07 PM   #15
A good rule of thumb perhaps, but not true on the Subarus AFAIK. It might be true on Saabs, but a number of folks in Sweden are running E85 in their 9000 Aeros with, as I understand it, minimal modification. But, since I don't have all the details, I wouldn't try it just yet.
There's a really really good thread about E85 in gasoline engines (specifically the WRX, caveat lector) here: http://forums.nasioc.com/forums/showthread.php?t=803341
-Adrian
Old 11-02-2005, 04:47 AM   #16
DeLorean's Avatar
there are many pumps around here I have seen with a little sticker "this gas contains 10% methanol" I think the "danger" to fuel systems is overrated, the injectors are just metal solenoids and most of the fuel lines are a gas rated plastic. you are not going to damage any car with a gas additive that contains ethotal/methanal because that would put your percentage of it in your fuel system well under 10% also, 10% is more or less a safety factor. almost any car would probably run fine on a 50/50 mix for years but eventually the fuel pump seals some o-rings or a fuel line would fail on the expressway and you would have a nice little barbq
in the future I would bet you are going to see more cars that can take a much higher mix. if you could run 50/50 mixture in every car, we would burn about 1/2 as much gasoilne.
DeLorean is offline
Old 11-02-2005, 12:35 PM   #17
Seafoam is awesome stuff, as is regular water for engine cleaning. I read a lot about it and used it when I had a Camry with some lifter noise. When sucked in through a vacuum hose into the engine it expands rapidly removing deposits from the internals. Good rule of thumb to change oil after using any additive like this. What I read is that plain water does the same, and that either is bad for a turbo because the expanding liquid can damage the compressor blades.
Old 11-03-2005, 09:30 AM   #18
Send a message via AIM to szucman
my frriend who has a volvo (not sure which model but it has a turbo) used it and told me that it was amazing. so i tried it to clean the intake valves on the 900se by sucking it through my bpv vacuum line and the stuff is great. the motor runs so much better now, so much smoother. and that was about 4 months ago.
szucman is offline
Old 07-30-2007, 08:01 AM   #19
HNNLIC
Blaque's Avatar
Bump after about a year and a half.
Im considering adding the Seafoam, but noone was really sure on how it would work on a charged car.
Anyone try it on a turbo yet?
Blaque is offline
Old 07-30-2007, 09:59 AM   #20
drewz airflow se's Avatar
I know someone who has done it on saabnet.
^CLICK ME^
drewz airflow se is offline
