BCR8ES Gap: Too Tight? - The Saab Link Forums
Old 01-31-2013, 04:29 PM   #1
I imported some BCR8's and they come from the factory with a tight gap; .03" tight. I know they are a colder plug, but my knowledge of spark plugs is that their "heat" refers to the design of the insulating cone with respect to the outer, threaded, housing. In this recess is where the heat of a plug is determined(hot plugs hold more heat in this area, colder plugs less so) and not across the gap, IIRC. As such, I feel this gap is too tight--even for my high boost applications (30psi&w/m).
What say you?
-Cm
Cm452 is offline
Old 01-31-2013, 07:22 PM   #2
Greek Mod
grkguy89's Avatar
where and how much were they?
that's a good gap IMO
i run that gap, if not tighter
Current Activity: Moderating
grkguy89 is offline
Old 02-01-2013, 06:59 AM   #3
I got 'em off ebay for 9GBP +5GBP international shipping from:
4X NGK Copper Core Spark Plug BCR8ES 5430 | eBay
Took about a week to get here. I haven't put them in the engine yet, so, I don't know how they run.
They are obviously a colder plug, with no projector and a shallow and wide recess.I'm psyched!
-Cm
Cm452 is offline
Old 02-01-2013, 07:02 AM   #4
FWIW; I run .035 on the BCPR7es 11's just fine.
-Cm
Cm452 is offline
Old 02-01-2013, 10:47 AM   #5
So it turns out Google has a better search algorithm than the forums do...after more extensive searching it turns out that the factory gap on 'em is just right, maybe up to .9mm or .035".
Now, the temptation is to go add a blanket .5 degree advance to the entire global ignition map....ooooh how tedious column by column tuning is
-Cm
Cm452 is offline
Old 02-02-2013, 03:37 AM   #6
-Cm
T5-Suite will do global changes on a table -- no tedium at all. It'll take longer to re-flash the ecu than to change the table.
win_k is offline
Old 02-02-2013, 06:36 AM   #7
I know....I also know that I have spent considerable time ironing out the timing and that there are several spots on the map that I have given much attention to and finessed the timing to within 1/2 degree of perfection.
With a global change I then run the risk of having to redo those sensitive areas and address other, new trouble spots. The risk with adding .5 degree globally to a "worked" map is that it could push it over the limit and I don't know in how many places at once I'll have to address the matter. Again, my being laz.,
-Cm
Cm452 is offline
