Idle Hunting Issue - The Saab Link Forums
Old 10-30-2012, 11:14 AM   #1
Idle Hunting Issue
Hey All,
As some of you may know I have boosted my N/A NG900 and am having idle issues with it... I have tried numerous resolutions to no avail and I am desperate for any insight that any of you might have.
The situation:
  • At initial start-up the car idles high (around 1500 rpm)
  • Once driven the idle starts hunting when in neutral or stopped completely (usually from 1400-1800 rpm)
  • If stopped the car will continue to hunt unless given additional gas (when given additional gas the car will then have a steady high idle of about 2000rpm)
Things I have tried:
  • New MAP Sensor (no change, put the old one back in)
  • Different ECU - I have one that JZW tuned for me and one that JZW tuned for grkguy89, which worked for him (no change)
  • Checked vacuum lines (they are all new silicone anyway)
  • cleaned IAC valve (no change)
  • replaced IAC valve (no change)
  • used an IAC valve from a 9000 (resulted in a higher hunting idle)
  • fresh spark plugs (no change
  • swapped DIC (seems to temporarily resolve the issue, but then the system adjusts back to hunting)
  • Switched back to the n/a throttle body (no change)
At this point I am thinking it has something to do with my fuel system (pump, regulator, injectors), but I really don't know.
Any suggestions or ideas are more than welcome - This is driving me insane!
Shaner3721 is offline
Old 10-30-2012, 11:31 AM   #2
Wagon Shaggin'
Saabeh's Avatar
Vacuum leak.
Saabeh is offline
Old 10-30-2012, 01:40 PM   #3
PimpMyPc's Avatar
Pinch off the IAC line. The car should almost if not die.
I bet its still the IAC. I've pitched out numerous ones that started doing that. I've even had ones straight out of the junkyard do that.
Smack the IAC with a hammer when its doing this and it should settle down.
PimpMyPc is offline
Old 10-30-2012, 03:34 PM   #4
Originally Posted by Saabeh View Post
Vacuum leak.
You wanna elaborate on your thoughts? Do you have a good idea where a vacuum leak like this could be coming from? I have checked the small lines, they are actually all new silicone...
Really? I will definitely be doing this! Does it matter which side of the IAC line I pinch off?
Thanks for the ideas!
-Shane
Old 10-30-2012, 05:23 PM   #5
Greek Mod
grkguy89's Avatar
im fighting with my throttle body right now
the throttle plate shaft is causing a vacuum leak behind the actuator
Current Activity: Moderating
grkguy89 is offline
Old 10-30-2012, 07:59 PM   #6
So I went out to mess with the IAC valve/line and could literally hear a vacuum leak in the bay... checked all the standard vac lines and they were fine. Then I realized the leak was coming from the evap line connection to the throttle body. The line was completely ripped open and causing a nasty leak. As soon as I put my hand over the line to seal the connection the idle calmed down. The only problem with this is that I know this line hasn't always been like this... I temporarily wrapped the line up with tape to test it out. The idle was instantly at 1000 rpm when I started the car back up. I took it for a spin and it was definitely a lot better, but eventually the idle creeped up higher and higher and then almost started hunting (just barely). Next thing I did was pull the line that is attached to the other side of the purge valve and put my finger over the purge valve opening. This seemed to calm the idle back down.
What I have done now is completely removed the evap connection on the throttle body and sealed the port. Took the car for another spin and it still increased the idle as I drove. I currently have the battery disconnected and am hoping that by resetting everything I can get this sorted out.
Old 10-30-2012, 09:38 PM   #7
PimpMyPc's Avatar
As before, smack the valve with a hammer when the idle is high. If it settles down then replace the IAC.
PimpMyPc is offline
Old 10-31-2012, 07:11 AM   #8
I tried that last night and it didn't do anything, but that might have been because the evap system was causing the big issue... I will try this again when I have some time to look at it.
Old 10-31-2012, 07:12 AM   #9
This morning when I drove the car (without evap connected) it was much much better. Initial idle was at about 1,000 rpm (what's normal?), but upon driving the vehicle idle increased as I kept driving.
At this point I am thinking that, for some reason, my throttle is getting stuck slightly open after the engine runs/drives for a while and opens the throttle. Let me know if you guys think this makes sense.
Thanks for all the help,
Shane
