Cam Replacement and ENEM Cams - The Saab Link Forums
Old 10-19-2012, 08:52 PM   #1
Greek Mod
grkguy89's Avatar
CAM REPLACEMENT (T5 cam upgrade for you T7 guys)
Place the engine in Top Dead Center
Remove valve cover (Duh!)
Zip tie cam gears to the chain (so you dont lose timing) and remove them off the cams (14mm)
On the timing chain tensioner, remove the 12mm cap off , (be careful there's a spring in there that can shoot out)
And then remove the chain tensioner (27mm)
Then start from the center caps and break them loose and work your way out releasing the tension slowly and evenly (13mm)
Lube up the T5 cams (Remember there is an Exhaust cam and Intake cam)
Then start tightening them down from the center cap moving your way out again, making sure you bring the cam down evenly
8 4 1 5 9
7 3 2 6 10 <--- sequence for each cam to loosen and tighten caps
Torque caps to 11ft.lbs.
Torque sprockets to 47 ft.lbs.
Current Activity: Moderating
grkguy89 is offline
Old 10-19-2012, 08:52 PM   #2
Greek Mod
grkguy89's Avatar
ENEM Post
grkguy89 is offline
