some tuning advice - The Saab Link Forums
Old 10-11-2012, 11:50 AM   #1
some tuning advice
hi all im new to saab tuning,done jap stuff before,just afetr some advice,do saabs run better with or without dump valve,i like the sound.what make is best for car.whats a good intake for the car and can you get yprated actuator for my model,its a 9-3 aero hot,y reg.
scoobypower is offline
Old 10-11-2012, 12:45 PM   #2
Wagon Shaggin'
Saabeh's Avatar
Saabs run better with an appropriate Forge (or the like) recirculating bypass valve. You want to hear it? Get an open intake.
Saabeh is offline
Old 10-11-2012, 01:32 PM   #3
What year? If it is a '99, then a dump valve is fine. If you have a black brick on the center of your engine (DIC) then you cannot run a BOV; you need a recirc.
-Cm
Cm452 is offline
Old 10-12-2012, 03:31 AM   #4
its a 2001 y reg,also what is the best oil for the car.
Old 10-12-2012, 04:13 AM   #5
mike d's Avatar
stick with the recirc valve even on t5 cars,, the open air valve are always trouble
MikeDTuning.com
mike d is offline
Old 10-12-2012, 05:17 AM   #6
why are they trouble
Old 10-12-2012, 07:24 AM   #7
Mike d; you are a very knowledgeable guy and tune, which is the next echelon so to speak. However, it is essentially impossible for a BOV to effect a T5/MAP system. BOV opens, manifold sensor sees less pressure and a corresponding drop in air volume, systems acts accordingly. On a MAF system the air lost has already been counted and the system has an unaccounted variable introduced, which leads to error (rich).
I'm very curious as to your reasons for stating what you did.
-cm
Cm452 is offline
Old 10-12-2012, 07:27 AM   #8
Wagon Shaggin'
Saabeh's Avatar
-cm
Mike D understands this don't worry. It has nothing to do with effecting the tuning, its drive-ability. Any competent tuner will rather have a recirc valve. You don't lose all the boost you just created by shifting.
Saabeh is offline
Old 10-12-2012, 08:14 AM   #9
The ECU is monitoring the air coming through the MAF. If you dump some of it out of a BOV, you piss off the ECU.
Unless you're just looking for sound, this is not something you need to think about in terms of performance enhancements in 99% of cases.
BobSabbert is offline
Old 10-12-2012, 08:33 AM   #10
Jaws's Avatar
No MAF on T5 Bob. It is funny how these things go full circle. I would have sworn that a BOV would result in better boost response because 1) you are not blowing hot air back into the intake and 2) said hot air is not pushing back on the compressor in the wrong direction. It is interesting to hear this different perspective from Mike and Saabeh.
Jaws is offline
Old 10-12-2012, 10:04 AM   #11
Wagon Shaggin'
Saabeh's Avatar
You CAN run one.
You CAN also run Champion spark plugs.
Saabeh is offline
Old 10-14-2012, 01:39 PM   #12
OP has a 2001 - T7 w/MAF.
Old 10-14-2012, 01:49 PM   #13
mike d's Avatar
-cm
the open air valve being trouble has nothing to do with how it effects the trionic system on t5 cars, and everything to do with the fact that open air valves are just a shitty design.
open air valves always seam to either open to late causing some form of compressor surge, or open to early causing a boost leak. whereas a single piston recirc valve never seams to have any of these issues. i dislike open air valves because they just suck to deal with,, not because of how they effect the EFI system
MikeDTuning.com
mike d is offline
Old 10-14-2012, 04:34 PM   #14
Fair enough But as for retaining boost made; one dumps into an open ended tube, the other into the atmosphere. Advantages are marginal for either one. What about running a recirc as a BOV, as many (including muhself) do with the Forge?
-Cm
Cm452 is offline
Old 10-15-2012, 05:22 AM   #15
mike d's Avatar
the forge valves are great,, but exspensive, i have had a 100% success rate with this valve
below is a good video showing how these "cheap ebay" valves are made. its a pretty simple design compared to how an atmospheric valve works
http://www.ebay.com/itm/Bosch-Turbo-...-/150917242100
BYPASS VALVE AUDI VW PORSCHE TURBO BOSCH SAAB DIVERTER | eBay
MikeDTuning.com
mike d is offline
Old 10-15-2012, 06:32 AM   #16
Bosch Turbo Bypass Valve for Audi Porsche VW Volvo Diverter | eBay
That's what I run. Single piston BPV turned BOV. Bootleg forge with exact specs as forge.
Cost me the same, too.
-Cm
Cm452 is offline
Old 10-31-2012, 05:30 PM   #17
m-192's Avatar
Originally Posted by Saabeh View Post
You CAN run one.
Blasphemy!!! Ha just kidding I run ngk. But I put autolite in my moms. Hehe
1999 saab 9-3 JZW stage 4
m-192 is offline
Old 10-31-2012, 09:23 PM   #18
comtrang's Avatar
What BPV? I pulled mine off and plugged the holes
Daily Driven '00 Saab 9-3
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 11-01-2012, 12:49 PM   #19
Why don't you like your Mom?
Old 11-01-2012, 01:56 PM   #20
m-192's Avatar
Ha we'll the place I bought the plugs from only had one set of ngk's. plus she won't know the difference.
m-192 is offline
