Help with transmission swap please!! - The Saab Link Forums
Old 09-21-2012, 03:35 PM   #1
Hey guys. Just took the viggen in for a transmission swap. Now, after the fact, the shifter isn't centered anymore. If anything, it's aligned with first gear? any idea on what could have happened and/or how i can fix it?
Also, i had the radiator replaced along with accessory belt, water pump, idler pulley, and tensioner. After everything was put in (trans and etc.) the car now has no power. It's barely putting along and it barely has any throttle response at all. Whether i floor it or not its the same. The mechanic has no idea why and i was wondering if there was anyone who has any idea what is going on.
Thanks for you help guys.
viggenftw is offline
Old 09-21-2012, 03:40 PM   #2
viggenkid's Avatar
Sounds like you went to the wrong mechanic
viggenkid is offline
Old 09-21-2012, 05:08 PM   #3
bogan's Avatar
It's hard to find a good mechanic.
You need to properly re-align the shifter
25.03.2005: Saab NG900 Shifter Alignment - photo.platonoff.com
Do you have a check engine light ?
bogan is offline
Old 09-26-2012, 04:20 PM   #4
no check engine light. the car just has like no power... so no idea what could be causing this? maybe a sensor in the wrong place or a screw put in the wrong place or a sensor hooked up wrong?
yea he's not someone who's worked on saabs before... he took good care of my buddys srt4 which is why i went to him in the first place but he cant seem to figure out whats going on here... anyone else?
Old 09-26-2012, 04:22 PM   #5
thank you for that link btw i shall try that
Old 09-26-2012, 04:29 PM   #6
one question related to the linkage... in step 4 it says move the lever to align the hole in th elinkage rod... what lever? does it mean the shifter? what exactly am i trying to align the whole to?
Old 09-26-2012, 05:34 PM   #7
I haven't done this personally... Yet (I will be doing it this weekend though). I believe that You move the "lever" or shifter to align the hole in the front with another hole that is visible below. This will align the shifter.
Thanks,
Joe Reichard
10 Saabs
1 Mercedes
Complete Addict.
Slow Joe is offline
Old 09-27-2012, 02:38 AM   #8
Harvey's Autohaus's Avatar
I discussed shifter alignment @ the end of this thread. https://www.saablink.net/forum/perfor...-3/57262-3.htm
HakbarSAABzzz
Harvey's Autohaus is offline
Old 09-27-2012, 09:31 AM   #9
nice... thanks harvey... so does anyone have any idea why im not getting any power after all that work was done? i can floor it in first n the car just barely has the power to move... n it doesnt matter if i floor it, or use light throttle it's the same thing... anyone?
Old 09-27-2012, 09:55 AM   #10
JZW
Sounds like boost leak, one of the ic clamps is not tight and all the boost just goes out past the clamp. Do a simple W hose test, pull the W hose, the middle hose on the BPC or boost pressure control valve and if it boost fine, then its the bpc or something, if it still does not boost, its most likely a boost leak somewhere,
John
JZW is offline
Old 09-27-2012, 12:10 PM   #11
thanks john ill have him check that... its funny cuz i can hear the boostand when boost kicks in the car does pull a little more... anyways ill tell him to check... now what is the W hose?
Old 09-27-2012, 01:58 PM   #12
Turbo00's Avatar
Platonoffs shifter alignment is a great walkthrough, just need a couple small allen keys to keep everything lined up. You don't realize how off your shift is until you go through the process.
As far as power, does it sputter at all? If he replaced the radiator chances are he had to unplug the BPC. Verify that the vac lines are all in the right place. Check the lines/clamps on the cast aluminum pipe that goes from the MAF to the intake side of the turbo. Basically, look at where all the parts are that he replaced, and if it looks like he had to move/take something off, look around for odd connections or unplugged vac lines.
Turbo00 is offline
Old 09-28-2012, 02:51 PM   #13
Is there any diagram for how the vacuum lines should be? Where is the bpc located? He checked turbo lines they were clamped properly... thanks for the support guys I can't wait to get her back haha
Old 09-30-2012, 08:25 AM   #14
^^ anyone?
Old 10-02-2012, 09:52 AM   #15
Originally Posted by viggenftw View Post
^^ anyone?
The BPC is on the passenger side next to the radiator. It has three hoses connected to it and a two pin electrical connector on top with a wire connected. The hoses are labelled (lettered) and one says "W" adn goes to the wastegate. There are two more hoses that run down to the turbo.
Diagram: http://img.photobucket.com/albums/v1...ionDiagram.jpg
Photo of BPC: http://www.npr.fi/~heikki/misc/T7_BCV.jpg
BobSabbert is offline
Tags
power, problem, response, throttle, transmission
