Innovate? Me? - The Saab Link Forums
Old 08-26-2012, 07:58 PM   #1
Innovate? Me?
I think my wideband is on the way out. I left for work overseas this summer. Car was started and driven 3 miles in my absence and presumably run gently. Over the summer the battery died and I lost all the adaptions. Cool. Returned and jumped it, reloaded the SAME flash and have been driving it a lot. I've noticed that now it does this weird "tugging" on the highway when at the edges of the "vacuum" maps. Meaning, when it is in CC, going downhill let's say, and TPS is low, like 3-10%, and vacuum is high, like 20 InHg, I'll notice on T5 dashboard I get a reading of ~12-15AFR. Target is ~17 and VE maps are ~ bottomed out. It's in Closed loop, with Lambda on transients and general lambda control.Similar thing happened a LONG time ago when I told the ECU to NOT use lambda on transients because I's workin' on 'em .
Fast forward; today it did this shudder/jiggle thing on downhills for 3+ hrs on a long drive (worst yet). When I got home, it had developed hiccups @ idle and AFR did NOT stay in it's happy 14.7 place (usually within 10%). Now it swings from 12-16...
Anyway, setup is direct, wideband-to-bung (no spacer) and the LC1 is nestled in plenum area. Feedback AFR states this trouble zone is ~17 afr, not stoich. Lc1 and sensor have suffered 3k of HARD driving.
What is going on? Cooked LC1 sensor? Maybe a leak in W/M? I don't think it the culprit...
Help please,
-Cm
P.S I just read on ecu-project from a newbie that since I have the ECU being fed off a simulated narrowband that 17afr target is not possible in the black closed-loop boxes. It needs to be 14.7 across the whole board wherever those black boxes are, correct? Logic: computer aims for Lambda=1, even if target maps states Lambda >1, comp can only "see" numbers close to L=1?
Cm452 is offline
Old 08-28-2012, 05:43 PM   #2
NeedForSwede's Avatar
Did you recalibrate the sensor? It sounds like somethings off, but it might be worth a shot.
NeedForSwede is offline
Old 08-29-2012, 10:26 PM   #3
Yup...helped a little. As I said above, it happens in the area between engine brake fuel cut and very slight tps. I wonder if the problem is that I tightened the throttle cable and in doing so narrowed the gap between TPS engagement and fuel cut.
It is also accompanied by a BTDC of half its targeted advance, so ~9 as opposed to 20.
'Tis a most curious development,
-Cm
Cm452 is offline
